Help-what Does The Air Bypass Valve Do?
4 replies to this topic
#1 racers
racers
    Just On Tickover
  • 5 posts
Posted 01 May 2008 - 06:50 PM
We posted a wanted add for a idle air control valve which seems to be broken off in our 1275 mpi engine. Is the idle air control valve and the air bypass valve the same? Also what exactly does it do? We are having a very difficult time trying to find a new or used one. Any help would be greatly appreciated. Thanks
#2 Dylan8660
Dylan8660
  • 206 posts
Posted 02 May 2008 - 08:59 AM
If you want a used one then try your local scrappy for a k-series rover as most the inlet gubbins are shared, always good to have a few spares knocking around.
#3 racers
racers
    Just On Tickover
  • 5 posts
Posted 03 May 2008 - 01:00 PM
Thanks for the info!
#4 Ethel
  • 26,130 posts
Posted 03 May 2008 - 01:15 PM
See if you can get a part number then do some googling to find likely donors. The injection system on MPI's is top end Memacs stuff as used on VVT engines - dunno if that also applies to the air valve. Which, incidentally, acts like a second throttle controlled by the ECU so it can hold a steady idle etc when your foot is off the pedal.
#5 racers
racers
    Just On Tickover
  • 5 posts
Posted 04 May 2008 - 01:25 AM
Thanks for this info, we are slowly getting closer so finding this part.
