Mpi To Turbo
6 replies to this topic
#1 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 05 May 2008 - 10:12 PM
I am currently driving a 1.3 mpi, but also have a newly rebuilt metro turbo lump sat in my garage. What would need doing in order to fit this turbo lump into my mpi mini?
Want to try and get a list together of absolutely everything that needs doing.
#2 bamby
bamby
  • 1,342 posts
  • Local Club: Fylde Mini Club
Posted 05 May 2008 - 10:17 PM
well youd have to sack the entire mpi engine part for starters, and convert half the electrics back to pre 96 , thats not to hard ,
your alarm and immob wouldnt work due to having no ecu (MEMS system) is it not worth adding to your mpi engine ? rather than swapping them over?
#3 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 05 May 2008 - 11:06 PM
Yea not fussed about immobilliser n alarm. Well its just i dont see the point adding to the mpi because i have a rebuilt turbo lump sat in the garage. Also dont fancy shedding out loads of money for an aftermarket ECU if i decided to turbo the mpi engine
Edited by d4v1dtyler, 05 May 2008 - 11:07 PM.
#4 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 05 May 2008 - 11:25 PM
You would need to weld in a turbo bulk head box unless using a fancy manifold and covert the wiring back pre 96...
#5 Ethel
  • 26,033 posts
Posted 06 May 2008 - 12:05 AM
The turbo lump will allow you to avoid the tougher emissions standards for your car: provided you can prove its age. It's probably worth the effort for that alone if you are looking for more power than an MPI can produce in fairly standard trim.
#6 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 06 May 2008 - 05:19 AM
easier and cheaper to sell the MPI and buy another mini and shove the turbo motor in that.
#7 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 06 May 2008 - 06:12 AM
miniboo why would it be easier and cheaper? If its only a case of welding in the bulkhead box and converting the wiring loom, then i couldnt imagine it would be that hard or expensive?
