Jumping Out Of Second Gear
12 replies to this topic
#1 lookieuk
lookieuk
  • 257 posts
Posted 05 May 2008 - 10:44 PM
Hi all
was wondering if anyone out there had this problem am having
well the story goes like this my mini is a 998 and the gears all work fine but second gear wants to keep jumping out
from 1st to 2st and 3rd to 2st...all the other gears are sweet as a nut no problem there
so dont think its the clutch could it be the gear is self gone or the change rod playing up?
hope some can help cheer peeps..:P
#2 1275john
1275john
  • 97 posts
Posted 05 May 2008 - 10:46 PM
Hi all
had this on my cooper second gear synchto on way out mate it most likly is engine out joby ,. while your there wack in a 1275 (if u can find one)
#3 lookieuk
lookieuk
  • 257 posts
Posted 05 May 2008 - 10:49 PM
check thanks bud will do and got a 1275 a mg one too...should be fun.. :P
#4 Ethel
  • 26,010 posts
Posted 05 May 2008 - 10:52 PM
It could just be something like the engine mountings allowing the engine to move and pull on the selector.
#5 lookieuk
lookieuk
  • 257 posts
Posted 05 May 2008 - 10:54 PM
mmmm how easy it that to check ethel..and to change + wouldnt that do it for all the gears?
#6 Ethel
  • 26,010 posts
Posted 05 May 2008 - 11:59 PM
Use a bar to lever the box in the subframe, see if there's much movement or signs of separation in the mountings. Still be quite hard to replacate what happens on the road.
The torque reaction of the engine will only try to deselect 2,4 & reverse and 2nd will see the most torque. Does it always jump out when you put your foot down or let the clutch out sharpish?
It could be a fault with the syncro, but that would likely cause crunchy gears as well 'n it'll be cheaper 'n less hassle to look at other possibilities first.
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 06 May 2008 - 02:30 AM
I don't wish to sound alarmist but it could just as easily be worn shift forks and/or detents. This is particularly true if you or a previous owner had a habit of driving around resting your hand on the gearshift lever.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 May 2008 - 06:00 AM
The usual time for a rod to knoc out of gear is when it's not under load, ie, turning a corner and basically free wheeling...
The cause is knackered synchro springs, and possibly a gear with worn dog teeth...
#9 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 06 May 2008 - 06:13 AM
You mean the adjustable engine stabiliser on the bottom, not being done up tight
#10 lookieuk
lookieuk
  • 257 posts
Posted 06 May 2008 - 08:36 AM
Thanks for all your comments guys
it wants to come out of 2st when i put load on it.... can hold it in... if i keep my hand on the gear stick and hold it in place...erkk
but dont fnacy driving around town like that and it does grind sometimes which make a nasty noise :D
will get under it in a few days and see what i can find out with your info :wub:
#11 lookieuk
lookieuk
  • 257 posts
Posted 06 May 2008 - 10:49 PM
:thumbsup:
#12 tinker1981
tinker1981
  • 10 posts
Posted 06 May 2008 - 11:17 PM
It's a worn selector fork, or could also be the little black press fit bush in the back of the diff that no one ever changes. :owned:
#13 mastermute
mastermute
    Just On Tickover
  • 9 posts
  • Local Club: MCS
Posted 16 July 2008 - 10:05 PM
but dont fnacy driving around town like that and it does grind sometimes which make a nasty noise :lol:
will get under it in a few days and see what i can find out with your info :P
Did you ever find out what it was? I have the exact same problem; It's a long way to engage, and when i put load on it, it jumps out...
And according to the previous owner it's a refurbed gearbox :P
