Mot Failure
Posted 08 May 2008 - 09:54 PM
My mini has just failed its MOT - (its a strange feeling owning a mini and waiting for the MOT test, its kind of how i imagine it is for a parent when there child has a test)
Anyway... She has failed on;
Offside front suspension joint has excessive play in a lower suspension ball joint (apparently not a huge problem)
She has also failed on emissions - Carbon monoxide content after 2nd fast idle excessive and Hydrocarbon content after 2nd fast idle excessive... i have been told that this can be a time consumining issue and obviously ill be charged labour fee's while there looking for the issue... can anyone advise me if there is anything i can do... Im definately no mechanic but am more than happy to follow instructions if someone has any advice.
Results are Carbon Monoxide (1st Max - 0.300, Actual - 0.839) and (2nd Max 0.300, Actual 0.58 and Hydrocarbon content after 1st and 2nd fast idle excessive (1st Max - 200, Actual - 983) and (2nd Max -200, Actual - 195) if anyone knows what the numbers mean!
she also has a few adviseries such as brake pad and tyre - nearside ball joint also could do with a change...
I also wanted to ask if maybe the ball joints being duff is the reason my ride is so hard... i know minis are hard but i can fell every single stone
Thanks in advance
John
Posted 08 May 2008 - 09:59 PM
emmissions could be a few things.....catalyst, engine not warm, too warm(like today was)lambada sensor, air filter, spark plugs.
brake pads are ten mins to change.....
Posted 08 May 2008 - 10:15 PM
baal joints maybe two hours a side to chnage, easy if you have the tools and a vice!
Cool thanks for replying so quickly!
Im pretty new to actually doing any work to my cars but buying a mini it seems a good time to start learning!
I will definately have a bash at the brake pads but will probably leave the ball joints to the garage as they have quoted £55 for each one inc parts and labour... I am mainly worried about the emissions as they have said it could take a while to find the problem - all the while im footing the bill for labour fee's - so basically im trying to find out as many things that i can do to try and correct the situation not only to save them time and me money but to learn for the future... as i imagine i will need the info again in the future
Posted 08 May 2008 - 10:24 PM
Posted 08 May 2008 - 10:28 PM
for the emmisions, give it a service, new oil, air and oil filters, check the plugs and try filling the tank with shell optimax, I had to do this on my spi a few years ago as the fuel I got from tesco was so bad I'd never have passed the test.
Just to check... and this maybe a really silly question but a 1995 Rover Mini Cooper is definately SPi... i just wanted to make a 100% sure
Posted 08 May 2008 - 10:30 PM
Posted 08 May 2008 - 10:31 PM
Posted 08 May 2008 - 10:46 PM
Has anyone heard this before?
Edited by Millso24, 08 May 2008 - 10:48 PM.
