Turbo Cutout Box
14 replies to this topic
#1 wdsk
wdsk
  • 29 posts
  • Local Club: The castle
Posted 09 May 2008 - 08:40 AM
OK, so i have done all my body work... and half way throught the engine....
i was not going to go turbo, but i have changed my mind once again!
the cut out for the turbo to sit in, does this have to be there?... i did ask on turbo minis.. but did not get much feedback!
i mean i don't want to losse my heater matrix.. or bolt it further forward... can i still add the turbo with out the box cut out!..
some guy said yes, and gave me a link .. but i did not find any thing to helpful on the site.... can any one shed any light on the manifolds, turbo, carbs and chambers i will need...
thanks!
thats the only bit on a mini i am not to clued up on... but i would about 12-16psi of boost!... :kiss:
#2 adster
adster
  • 293 posts
  • Local Club: www.turbominis.co.uk
Posted 09 May 2008 - 07:24 PM
basically yes you will need to cut the bulkhead to give room for the turbo, or alternatively you could use the mirage manifolds and that would mean you can leave the bulkhead as it is.
hope this helps.
#3 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 09 May 2008 - 09:36 PM
yup, you'll need the mirage manifolds and a T2/T25 turbo, you can use the normal metro turbo inlet/carb/plenum etc.
this is what they look like with a T25 fitted and cost £350 from http://www.miragemotorsport.com/ (click on mini)
#4 mini_lad_1990
mini_lad_1990
  • 614 posts
  • Local Club: aint got one yet!!
Posted 11 May 2008 - 08:07 PM
the picture above is that how the t2 turbo would sit aswell??
cheers
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 11 May 2008 - 08:43 PM
You can rotate the compressor housing to point in a better direction, if that's what you were looking at.
#6 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 11 May 2008 - 08:54 PM
im not to good on this but i spoke to me mate that had a metro turbo in his and cut the bulk head out but finding these manifolds have changed my mind with the bilk head cutting
i was just wondering the t2 turbo fits on to the manifolds but i was also wondering if the t2 is best for the 1275 engine with this layout??
also does the wireing need changin over and is it hard??
cheers
#7 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 11 May 2008 - 09:39 PM
yeah the comp housing needed rotating, i'd just put it together to make sure it fitted ok.
I'd say a T2 is definately the way to go on a 1275 engine, pretty sure phil would agree too.
Don't need to change any wiring apart fromt he dizzy/coil and starter depending what you've already got and waht you will be using.
#8 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 11 May 2008 - 09:52 PM
what i already got?? do you mean what engine i have i thought i would have to change them but me mate said about the other stuff fuse box lights ect but i didnt think that would come into changing the engine
would i need the metro loom for the dizzy starter ect or just modify the mini one??
i am deffently convinsing myself to go down the mirage manifold route lol i just want a bigger engine but having the turbo just puts the biggest smile on my face haha :closed:
apart from the few other things its just get the engine do what i want,slap her in, rolling road then away i go??
what sort of power are you guys pushing with the metro turbo lump with the t2
cheers
#9 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 11 May 2008 - 11:31 PM
if you've already got non ballated electric ignition then you wont need to change the wiring for that, then it just depends what type of starter motor/clutch arrangement you use in the turbo lump compared to what you've got now.
The only other things you'll need to wire will be the fuel pump and inertia switch.
i dont know anyone running a std lump with a T2 to be honest.
With properly specced/built engines i'm running 160 horse @ 15psi on a t2, should hopefully be a bit more with a better matched turbo though. My mates running 190 horse @18psi on a T2. both of us are 1293cc.
#10 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 11 May 2008 - 11:51 PM
it wont be standard just keep the standard bore so i need to fnd all this out really lol i am so dumb
does anyone know about a roer mini studio 2 on a 1990 plate??
if worse comes to worse i will need to change the wireing (i hate electricals) has anyone on here done that??
also how would i check if i have the non ballated electric ignition??
cheers
Edited by mini_lad_1990, 11 May 2008 - 11:53 PM.
#11 wdsk
wdsk
  • 29 posts
Posted 12 May 2008 - 09:10 AM
brill thats great ... and the other guy asked some questions i wanted to!..
has any one fitted a 1.8 golf Tubro... called a KK03?
there are ment to be very small... just like a T2 or somthing?!
#12 Beats
Beats
  • 353 posts
Posted 12 May 2008 - 11:41 AM
The IHI unit on my Elan is extremely small.
#13 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 12 May 2008 - 01:06 PM
trouble is then you get into the realm of making your own custom manifolds/downpipes/oil feeds/drains etc.
Most people stick with the T2/25 flange because its easily do-able with normal garage tools onto a metro manifold or buying the mirage setup.
#14 wdsk
wdsk
  • 29 posts
Posted 12 May 2008 - 03:05 PM
yeah thats a good point... don't 100% sure if i want to try that!... just yet! :wub:
#15 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 12 May 2008 - 04:57 PM
does anyone know how to check to see if i have the non ballated electric ignition??
cheers
