Desperate Times....
19 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2008 - 10:04 AM
The supply of double roller bearings for gearboxes has dried up.. :kiss:
I have 4 left, so quite simple if you want a rebuilt gearbox ( with a new double roller ) get in there quick.
#2 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 09 May 2008 - 10:08 AM
JG - forgive my ignorance, but can you clarify this for me? Is using the double roller bearing a preference to another type, or does this mean there will be absolutely NO bearings available for rebuilding?
#3 Jammy
Jammy
  • 25,397 posts
Posted 09 May 2008 - 10:16 AM
I think guessworks is referring to the big double roller bearing that supports the mainshaft in the centre webbing. I don't believe there is an alternative, and only one is used per gearbox. Without it a gearbox cannot be built!
#4 Ethel
  • 25,950 posts
Posted 09 May 2008 - 10:26 AM
Surely someone can run a new production batch, but I imagine we can expect a bit of a price hike?
#5 minicb
minicb
  • 1,131 posts
  • Local Club: south-central-mini-club.com
Posted 09 May 2008 - 11:10 AM
We got a double roller bearing from MED this week for a job we're doing!!
Minicb
Edited by minicb, 09 May 2008 - 11:11 AM.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2008 - 11:22 AM
you can get the odd one or two, but when you're looking for 10+ you've got no chance....
I believe MS north have some but are only letting them out 1 per customer.
Edited by GuessWorks.co.uk, 09 May 2008 - 11:22 AM.
#7 robson
robson
  • 798 posts
Posted 09 May 2008 - 11:33 AM
thats outrageous, there will be an alternative knocking around somewhere, bearing specialist? Theres one down the road from me
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 09 May 2008 - 11:56 AM
Moss and MiniSport also still list them - but that doesn't mean they have many in stock. I can't see MS allowing such a crucial part to become completely NLA though.
Simon??!!
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2008 - 11:58 AM
Nope rang them this morning, apparently Minsport have a load of gearboxes on their shelf waiting for them :kiss:
So far I have tried...
Min-Its ( first place where I got the heads up )
MRA-Minis
Minispares ( all three of them )
Minisport
Minimine
DSN Classics
and I believe one of the major suppliers also has none
*shrugs shoulders*
Edited by GuessWorks.co.uk, 09 May 2008 - 12:01 PM.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2008 - 12:05 PM
Here's the tech spec if anyone has some nice local bearing shops...
RHP p/n MDJT25.4N=1
I/D (d) 25.40
O/D (D) 65.00
Width (B) 24.10
(b+b) 24.10
#11 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 09 May 2008 - 12:09 PM
We are pretty much in the hands of the bearing manufacturer RHP. Compared to when the Mini was in production, the number sof these required are significantly less, and with any manufcaturer, production numbers are key to whether it worth them making the part or not. We are applying huge amount of pressure to get these made, and I'll keep you posted on how we progress.
N.B. This is just one of a whole line of Mini parts that are getting harder and harder to get hold of, my job is definately not getting any easier
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2008 - 12:15 PM
As you say Simon, this is just the tip of the iceberg, now the mini has been out of production for near as dam 10 years, things are slowly running out.. and I suspect the likes of RHP are not interested in production runs which are not in the order of thousands of units.
#13 camp freddy
camp freddy
  • 3,696 posts
Posted 09 May 2008 - 12:28 PM
try these , i went in asked for a bearing ,showed him an example and he new
it was a mini bearing.. may be in luck. and localish to you...
http://www.leics-bearings.co.uk/
#14 blue redtop
blue redtop
  • 1,605 posts
Posted 09 May 2008 - 12:38 PM
RHP p/n MDJT25.4N=1
I/D (d) 25.40
O/D (D) 65.00
Width (B) 24.10
(b+b) 24.10
i know of a good bearing shop near me.if you want i can get there number.
they make them as well.
you might have a problem just ordering 10 - 15 tho.
you might need to order about 50 to get the price down.
#15 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 09 May 2008 - 06:16 PM
Tried Magpie in worcester John??
Still not recieved that CD :kiss:
