2 ohm and 4 ohm
4 replies to this topic
#1 roeman
roeman
  • 10 posts
Posted 19 May 2005 - 05:16 PM
Hi,
at the moment i have a 2x70rms 2channel amp running 2 6x9's(80w nominal input) 4ohm.
If i put 2 coaxial 16cm speakers in could i wire these up to the 2 channel amp? making the outputs 2 ohm? Would this make my current 6x9s less powerful? And would it work?
Cheers :grin:
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 May 2005 - 05:45 PM
if you run a amp at 2 ohm you will get twice the power out of the amp but you must have a amp that will take 2 ohms
#3 jamieoliver
jamieoliver
  • 341 posts
Posted 07 June 2005 - 05:45 PM
Dont know about other problems you will encounter but if you power it up that way you will lose sterio sound (either front/back or left/right). That was the advice i was given and i dont pretend to know exactly how it works but when i heard it, it made sense. May be worth finding out more.
#4 Pavel
Pavel
  • 2,451 posts
Posted 07 June 2005 - 06:19 PM
Basically you won't have a fader (front to back volume level balance). This is assuming the coaxs go in the front.
If I were you I wouldn't bother. Either just stick with the 6x9's in the back, or if you can get a set of cheap components for the front and bin the 6x9s.
You could sell your 4 speakers and buy a cheap set of components that will sound great up front...
#5 Scarface
Scarface
  • 288 posts
Posted 07 June 2005 - 07:10 PM
Rite if ur amp is 2ohm stable then this is what ull get:
2x4ohm speakers in parrallel= 2ohm
4x4ohm speakers in series/parallel=4ohm
can't rember what this does to power outputs etc... also think it depends on mono and stero ohms aswell. Hope this is a start.
If it ends up halfing the power u might aswell power the 6x9's of th hu and wire the comps to the amp or buy a 4ch amp.
