About 3 months the battery was losing its charge a lot so I bought a new Pug 306 diesel battery which did the trick! But once again I'm having problems with the battery draining (sometimes below 12v!) and hence the car won't start. I've been solving this by putting it on charge every night but as its my daily runner I could do with repairing it asap!
I've done a search on here and tried all the following
1) Got battery checked out at two places who said its fine
2) measured the voltage at the alternator (14v+) and the battery (13.5v+) when the engines running
3) cleaned up engine earth and battery earth, checked the under the car lead, cleaned up alternator connector
4) made sure alternator belt is tight enough
5) checked battery in series and drain was only 0.03amps, think it was due to alarm/immobiliser being on?
Halfords seemed to think the alternator was on the way out, they got me to start the engine and turn the lights on. This caused the battery volts to drop from 13.5v and when the heated windscreen was on it dropped to 12.9v! The alternator stays at a constant 14v+ though.
Should I just stump up and get a new alternator or can I check a few other things first?
The car seems to be kangarooing a bit now as well
Thanks for any help, might have to go to Himley 2moro to see if theres any bargains
