Weber Manifolds
5 replies to this topic
#1 RobG295
RobG295
  • 383 posts
Posted 11 May 2008 - 08:32 PM
Evenin' I'm currently looking for a project for my final year at uni (next year) and had a bit of an idea involving the weber manifolds. Basically i was wondering if there was a manifold available (apart from the swan neck type, which aren't all that great ) that enables a weber 40/45 dcoe to be fitted without bulkhead mods, but that doesnt impare performance?? I was basically thinking i could develop a manifold that does this, as it could be a very popular item if it works!!!
So was wondering a) if theres anything about that already does this, or
b) would it even be possible
Thanks in advance
Rob. :closed:
#2 alexcrosse
alexcrosse
  • 3,786 posts
Posted 11 May 2008 - 08:33 PM
no i wouldnt be possible. DCOE's must be mounted at 90 degrees to the engine, and the difference in distance between the inlet ports (width) and the distance between the 2 chokes on the weber has to be accounted for. Also, it has to clear the middle exhaust manifold.
Not possible im afraid.
#3 RobG295
RobG295
  • 383 posts
Posted 11 May 2008 - 08:42 PM
Balls! lol! Back to the drawing board then!
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 11 May 2008 - 09:05 PM
It is possible, I did it using a Maniflow 3.5" inlet
Paul
#5 alexcrosse
alexcrosse
  • 3,786 posts
Posted 11 May 2008 - 09:27 PM
still a bit of a swan neck though isnt it, absolutely ******* torque. And you cant get a good filter with good ram pipes on, thus... your better off with an SU.
#6 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 11 May 2008 - 09:32 PM
All manifolds will have a slight swan neck, I had over 140 bhp with the 3.5", shows its very good indeed. I now have 5". Torque is the same, but bhp is higher now
Paul
