http://s72.photobuck...s/i171/ted1979/
got some photos of the rear frame which is looking tidy
Eddie
Edited by edsmini, 16 May 2008 - 11:10 PM.
Posted 16 May 2008 - 10:53 PM
Posted 16 May 2008 - 11:21 PM
Posted 17 May 2008 - 08:42 AM
Hi and welcome to the world of zcars minis.
It looks like the frame design has evolved again judging by the photos
Looks very different but very functional att he same time.
What are your plans for the car?
Posted 21 May 2008 - 10:01 PM
Edited by edsmini, 20 July 2011 - 09:01 PM.
Posted 01 June 2008 - 09:37 PM
Posted 01 June 2008 - 10:20 PM
Posted 04 June 2008 - 09:17 PM
Posted 14 June 2008 - 10:35 PM
Posted 14 June 2008 - 11:00 PM
Posted 15 June 2008 - 12:00 AM
Posted 15 June 2008 - 12:36 AM
well i got the rear frame fitted today, although i had to cut the shiny new frame at the back to allow the car to fit over as the bracket that supports the exhaust was in the way ( not very happy about it but cutting the new rear valance back off wasnt an option as it is all painted )
is that a 5PW unit you're using ? and are you keeping the exup ?
I binned mine and I'm now wondering if its causing issues with the ECU and achieving full on acceleration and max revs.
thanks M.
Posted 15 June 2008 - 09:13 AM
Posted 15 June 2008 - 09:37 AM
i thought about the bolts to hold the rear valance on, i will re-attatch the rear frame back on with some custom sleeves and it will look fine and will remove without any problem but i was a bit peed at having to cut the frame in the first place after waiting 6 months on it but this was the best way i thought. i will get the sleeves powdercoated the same as the frame. chris said they might need to make it so that part unbolts. the final paint colour will be vauxhall power red i will have to find some wheel arches soon, hens teeth springs to mind genuine sportspack ones.well i got the rear frame fitted today, although i had to cut the shiny new frame at the back to allow the car to fit over as the bracket that supports the exhaust was in the way ( not very happy about it but cutting the new rear valance back off wasnt an option as it is all painted )
The shell hasnt got its final paint on yet, i would have personally removed it and made it removable via small bolts in the lip, a great shame reallyis that a 5PW unit you're using ? and are you keeping the exup ?
thanks M.
Think you are getting slightly confused, The hayabusa doesnt have an Ex up valve???
cheers
Posted 15 June 2008 - 01:17 PM
Posted 19 August 2008 - 02:40 PM
