Easy Detective Story
13 replies to this topic
#1 minijazz
minijazz
  • 173 posts
Posted 19 May 2008 - 06:04 PM
Hi all
I did a really silly thing and bought this engine/ box sight unseen- with a box and a CAM4610 labelled head with no bypass hole.
I thought I would follow the HBOL and rebuild an engine as a summer project.
The block has no number ( dammit ) but ONLY a casting number which is 12G 1279.
The pistons which came with the block are labelled AE 19320 and each has stamped on it +0.030. The bores on the
block are all 2.76 inches.
Could some kind soul tell me what this engine is ( or was !!). I'm assuming its a bog standard 998 a series leaded system.
I've attached a couple of photo's.
cheers all.
Colin
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 19 May 2008 - 06:12 PM
The size of the bore you gave in MM's is 70.14mm
Which seems to tally more with a 1275
http://www.austin-ro...ineaseriesf.htm
#3 Udo
Udo
  • 1,670 posts
Posted 19 May 2008 - 06:18 PM
As above 1275 block as no tappet covers on the back
If the pistons say +0.030 it has been overbored but my brain is letting me down on to what size, bigger than 1293 which is +0.020 so probably 1310 or something (someone please confirm)
I seem to remember a CAM4610 is a 998 head thou?
#4 minijazz
minijazz
  • 173 posts
Posted 19 May 2008 - 07:08 PM
#5 minijazz
minijazz
  • 173 posts
Posted 19 May 2008 - 07:12 PM
Hi
Thanks - time to get thinking cap on then..
cheers colin
#6 Pauly
Pauly
  • 4,213 posts
Posted 19 May 2008 - 07:22 PM
Its also an early a series engine (not a+).
Paul.
#7 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 19 May 2008 - 07:28 PM
well the blocks obviously been over bored by 30 thou, hence why each have +0.030 on so if you minus that from the bore size will leave with standard bore size, will then be easier to work out which it was starndard
#8 minijazz
minijazz
  • 173 posts
Posted 20 May 2008 - 06:14 PM
Hi Thanks
colin
#9 minijazz
minijazz
  • 173 posts
Paul.
Cheers colin
#10 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 20 May 2008 - 07:53 PM
I seem to think cam4610 is an A+ 998 aswell but dont quote me.
#11 IslandBlue
IslandBlue
  • 56 posts
  • Local Club: Mini Club Sussex
Posted 20 May 2008 - 08:15 PM
Bore for standard 1275 is 2.78" - same as the 970 and 1071 - but don't get excited 'because they don't have cast in tappets!
Block appears to have holes at either end for 10th stud and a bolt therefore my money would be on it being from a 1300GT.
Not certain about rebored capacity but as has been said +20 gives 1293 and +40 gives 1312 so +30 maybe around 1300?
Pistons AE 19320 are listed for 1300GT on following site - which I cannot vouch for - but would seem an unlikely coincidence!
http://www.deves.com...cars_AUSTIN.cfm
Hope this helps!
#12 minijazz
minijazz
  • 173 posts
Posted 21 May 2008 - 08:13 PM
Hi Island Blue,
Thanks very much its all good news really !
- us sussex locals have to stick together !
cheers colin
#13 tc001
tc001
  • 13 posts
Posted 18 July 2008 - 10:45 AM
Hi Island Blue,
cheers colin
I also have a A series block with AE19320 pistons, but mine are +60 making it a 1330, was wondering if you could still get replacement rings for them?
#14 Cooperman
  • 23,314 posts
Posted 24 December 2013 - 07:21 PM
At +0.030" it is a 1301 cc.
Piston rings can be bought from F.W. Thornton of Shrewsbury.
