What's Your Opinion Of Gunson's Colortune?
19 replies to this topic
#1 mkw
mkw
  • 1,003 posts
Posted 21 May 2008 - 12:28 PM
Hey,
I'm looking to set up twin carbs and i've been reading up on the colortune method, trouble is, it sounds to simple to be true!
What's your opinions and could you recommend a different method of mix setting other than RR.
Cheers!
#2 T.Harper
T.Harper
  • 714 posts
Posted 21 May 2008 - 12:33 PM
Yeh they're a giggle...
Ok to get it up and running, then go get it done properly!
#3 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 21 May 2008 - 01:56 PM
They're ok for getting the carbs to run the same - but not necessarily properly. More of a giggle is watching someone who really knows what they are doing set them up with a piece of hosepipe jammed in their ear!
#4 mkw
mkw
  • 1,003 posts
Posted 21 May 2008 - 02:03 PM
isn't the hosepipe in the ear for the airflow speed rather than the mixture?
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 21 May 2008 - 02:06 PM
Yep, for balancing the carbs.
The gunson tool for that is TOTAL rot. I ended up doing it by ear. As for mixture, it works aright for it. Just going "hmm, is that blue the same blue as the other side" for a while.
#6 Ethel
  • 26,141 posts
Posted 21 May 2008 - 02:21 PM
I can't see there are many alternatives, what else works cylinder by cylinder?
A probe up your tail pipe will just give you an average of all cylinders.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 May 2008 - 02:53 PM
personally I use one... and they can't be that bad when you consider my 1330 went on the rollers a month ago 3 years after it had been set up with one and was stuffing out 85 at the wheels...
What you have to consider is not only the use of the tool, but the person who's using it understands what they are viewing..
Like I have a crypton tuner in the unit, but I still use a strobe and a colortune to set up an engine because I don't fully know how to use the crypton. But it's useful for other things like putting my coffee cup on >_<
#8 helairmike
helairmike
    Just On Tickover
  • 9 posts
Posted 22 May 2008 - 01:18 PM
Provided it is used properly you can get good results and as another contributor says it is one of the only ways to get e measure cylinder by cylinder. From my recollection cylinder 3 on a standard head always runs a fraction weaker on the A series.
Oxygen/Petrol mix does produce precise changes to emitted wavelength of light emitted on combustion the variability comes in the operatives ability to see this corrrectly whichis dependant upon the amount of background light. In other words use it in a dimly lit area not in bright sunshine you will observe different results.
#9 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 23 May 2008 - 06:29 PM
No matter what i did to my car, my colourtune would always,.. ALWAYS, show blue.
Edit,.. carb was beyond worn! Colortune is fantastic! Have since setup the idle mixture on 4 engines and each is running beautifully
Edited by Retro_10s, 25 July 2024 - 06:15 PM.
#10 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 23 May 2008 - 08:28 PM
ive got one. use it along with the gas tester and its been ok to get normal cars setup. Anything like a wild cam etc its useless and just shows yellow all time even when it was running lean
#11 m1n1
m1n1
  • 769 posts
  • Local Club: I'm unsociable
Posted 23 May 2008 - 08:43 PM
Have used one a month ago to help set up my twin hif6 on the 1380. Didn't really need it to be honest but it was good to see the colour change of combustion; screw in till revs die and engine struggles - orange/yellow flame
screw out, revs pick up - blue flame
done!
#12 blue redtop
blue redtop
  • 1,605 posts
Posted 23 May 2008 - 09:43 PM
no mater what i did it would always show white.
but it did tell me to get some new needles.
once the needles were in it was a doddle to set up.
if your setting twin carbs up i would buy 2 colortunes as it was a pain swapping it over from one side to the other.
then sell 1 of them and get most of your money back.
#13 mkw
mkw
  • 1,003 posts
Posted 28 May 2008 - 08:30 AM
Thanks for the advice people! I'll give it a go with 2 of them!
#14 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 28 May 2008 - 08:39 AM
I have got a colourtune knocking about if you want a borrow rather than buying?
David
Edited by nomininolife, 28 May 2008 - 08:39 AM.
#15 mkw
mkw
  • 1,003 posts
Posted 28 May 2008 - 08:43 AM
David
I may take you up on that! I think tom has got one aswell so that could be the two i need...
cheers.
