Top Dash Rail And Scutle Rust
23 replies to this topic
#1 DaveRob
DaveRob
  • 703 posts
Posted 22 May 2008 - 05:48 PM
OK.... Pulled the windscreen and found all this
Attached File  DSCF0998.jpg   58.11K   69 downloads
Attached File  DSCF0999.jpg   51.6K   50 downloads
Attached File  DSCF1000.jpg   60.07K   32 downloads
Attached File  DSCF1001.jpg   60.54K   34 downloads
Attached File  DSCF1002.jpg   55.11K   21 downloads
Attached File  DSCF1003.jpg   55.1K   17 downloads
Attached File  DSCF1004.jpg   53.3K   17 downloads
Attached File  DSCF1005.jpg   60.39K   16 downloads
Attached File  DSCF1006.jpg   68.99K   18 downloads
Attached File  DSCF1007.jpg   76.21K   23 downloads
Attached File  DSCF1008.jpg   63.48K   24 downloads
Well looks rusty but not as bad as many.... Ive wire brushed to show the worst but bizzarly enough the bulkhead seems not to bad, I think I can patch the bulkhead bits in with fresh metal, its just the dash rail and scuttle thats the big prob.... is it new panels for rail and scuttle or is their either an option or more to it..... Ive already got new wings front and A's ready to fit..... do I need to go the whole distance...... Ive got Mig and TIG welders and a spot welder so fittings no issue.....
advice please as to what I should do and how to go about it.... ( and I havnt even lookd at the back end of Mini yet) lol
Rob
#2 liam_italian
liam_italian
  • 1,417 posts
Posted 22 May 2008 - 07:01 PM
Well with the amount of rust on that top dash rail I'd seriously consider replacing it, rather than trying to repair it mate!
You could possible repair the scuttle, then again might just be easier for you to replace that aswell!
#3 edi57
edi57
  • 821 posts
Posted 22 May 2008 - 08:54 PM
First of all...thanks for posting lots of decent photos...it always helps!
If I were you I'd be cutting out scuttle (complete) and cutting out the dash rail. Repairing the bulkhead, then new dash and new complete scuttle. That way you've done a proper job and so you know you wont be getting any rust come back soon.
Good luck!
#4 jack_marshall
jack_marshall
  • 2,540 posts
Posted 22 May 2008 - 11:44 PM
Just done this job.
Scuttle off, dash rail out.
Likely to need the pieces under each end of the scuttle too.
Not a terrible job really.
A genuine top rail from Minispares is only about 25 and fits well.
Think scuttles are a little more expensive.
#5 DaveRob
DaveRob
  • 703 posts
Posted 23 May 2008 - 06:53 AM
Thanks for the replies ..... I live only a few miles from M Machine so ill call their today for scuttle, dash rail and closing panels..... cut the old panels and fix the rust....and put new in....
Thanks again
Rob
#6 Geehawk
Geehawk
  • 500 posts
Posted 23 May 2008 - 07:28 AM
:wub: What age car is this?
#7 DaveRob
DaveRob
  • 703 posts
Posted 23 May 2008 - 08:01 AM
96 SPi
Rob
#8 liam_italian
liam_italian
  • 1,417 posts
Posted 23 May 2008 - 08:48 AM
Im not suprised, I had a similar thing with my 98 MPI, but not as bad! Id recommend after you've added your new panels, add a fine line of pu seam sealer between the panels where they join (Scuttle,bulkhead,topdash rail) this will help later on is water goes between the windscreen rubber and panel and stop it then getting between the panel joints and rusting away your panels again!
#9 Geehawk
Geehawk
  • 500 posts
Posted 23 May 2008 - 11:16 AM
96 SPi
Rob
Blimey :wub: They don't make 'em like they used to do they.
This is my scuttle on a 76 car, windscreen removed for the first time in about 20 years. Its solid throughout. I was pleasantly suprised.
#10 DaveRob
DaveRob
  • 703 posts
Posted 23 May 2008 - 12:35 PM
Was talking to one of the guys at M Machine today as I picked up new scuttle, dash rail and closing panels...... good job I have a TMF membership card that £10 has saved me £30 on panels and £25 on engine components.... and thats just this far lol.
M Machine man:.... what year is the car...
Me: 96
M Machine man:.... yer.... they do go like that with the later cars... all the early cars are fine... was the way they painted the later ones
M Machine man proceeds to display a Mk 1 Cooper in PRISTINE condition... there was nothing the matter with that one...
me:.......drools over said PRISTINE Mk 1
lol
Rob
#11 duncancallum
duncancallum
  • 533 posts
Posted 23 May 2008 - 12:50 PM
they changed the gauge of steel in the early 80's my 88 sky did it but the panel i cut off a well scabby 81 to let a section in was mint
my spi's goosed there aswell, after 40years of building them you'd think they would of lernt how to paint them
(after 25 years you'd think i'd of lernt to spell as well)
#12 jack_marshall
jack_marshall
  • 2,540 posts
Posted 23 May 2008 - 04:23 PM
Rover didnt care anymore as it got late into the production of minis!!
#13 DaveRob
DaveRob
  • 703 posts
Posted 24 May 2008 - 06:40 AM
Quick update before I get me welder out.... when I got the wings and A's off looks like I need to patch in some of the filtch?panel .......gonna buy 2 repair sections and use whats needed..... get some more of the rust cut off and get some new metal in their.... derusted primed and resprayed me front sub as well...seeing as it was a sunny day...
Attached File  DSCF1011.jpg   87.01K   49 downloads
Attached File  DSCF1013.jpg   79.51K   41 downloads
Attached File  DSCF1014.jpg   72.98K   39 downloads
Attached File  DSCF1017.jpg   100.08K   21 downloads
Rob :P
#14 edi57
edi57
  • 821 posts
Posted 24 May 2008 - 09:51 PM
Looking good. Keep keeping us updated!
#15 jcws_mini
jcws_mini
  • 10 posts
  • Local Club: Unknown
Posted 04 June 2008 - 02:55 PM
lookin good so far mate, well as good as it can look when its half a car :lol: . but if its gotta be done its gotta be done!
I have got to do the exact same job on my 1991 mini 998. i am a complete novice when it comes to grinding and welding so its gonna be a big learning curve. once i get the car indoors in our garage then i think the chopping and uncovering of probably evenmore problems will start.
Did you have any problems cutting the front end off? the bit i am not looking forward to is the scuttle panel, the thought of it being around the windscreen and the fact it needs to be accurate. will post pics soon and prob post a link in here to my topic.
keep up the posting and the work you know it'll be worth it!
