Brake Drum Screw
5 replies to this topic
#1 edi57
edi57
  • 821 posts
Posted 24 May 2008 - 07:53 AM
The screw holding on one of my front brake drums was way too tight and I had to get it off using an impract driver.
It's now looking a bit worse for wear so I need to get a new one.
I've been looking on MiniSpares website but I've not managed to find one. Perhaps I've not looked hard enough? Has anyone got a link?
Any possibility I could get such an item from Halfords?
#2 syholl
syholl
  • 710 posts
Posted 24 May 2008 - 09:44 AM
I typed in 'Drum screw' on Minispares, and look what came up... :P
http://www.minispare....aspx?pid=36738
#3 Ethel
  • 26,088 posts
Posted 24 May 2008 - 09:49 AM
1/4 UNF if you have a local nut 'n bolts guy.
You won't crash 'n die if you leave it off - well you may but it won't have any effect since you also have 4 wheel nuts keeping the drum on.
#4 blue redtop
blue redtop
  • 1,605 posts
Posted 24 May 2008 - 10:06 AM
i havent got any on mine and its totally safe.
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 24 May 2008 - 10:51 AM
Back when I didn't have any I used to put a run spanner over two studs, throw a two wheel bolts then adjust the shoes.
Found without screws the only problem you tend to have is that the drum won't always sit right with no wheel on.
#6 edi57
edi57
  • 821 posts
Posted 24 May 2008 - 09:47 PM
Ok thanks for the help guys.
Looks like another order to minispares soon.
