Identifying What Lsd This Is
2 replies to this topic
#1 duncancallum
duncancallum
  • 533 posts
Posted 25 May 2008 - 04:28 PM
I hve the chance to buy this diff out of a car my mates bought( a 1963 cooper that was used for some navigation rallies thats now back on its 998)
the box is a close ratio gear set and its got this lsd in it and i want to know what it is its got btra stamped on it
i know its an lsd as the joint roatate the same way and its feels fixed
any ideas:
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 May 2008 - 05:32 PM
it looks like a bad copy of a phantom grip...
not an LSD as such, but just a block which is wider than the normal which uses the clamping pressure which is introduced by crownwheel being bolted onto the diff cage to lock the diff.. more like welding the diff up..
The phantom grip uses two spring plates which attach round the diff pin in normal situations provides a free diff but when one output shaft starts to spin causes a friction/turning action on the grip which tightens up the pinions and outputshafts..
Personally, I wouldn't use it as it'll put a lot of stress on the already weak diff pin.
#3 duncancallum
duncancallum
  • 533 posts
Posted 25 May 2008 - 05:58 PM
cheers mate for that
bugger I was hopping that it would be worth havin I thought it may of been an old sailsbury type I knew it wasnt a quaif or more modern one.
you cant spin either shaft freely so i thought it must of been a plate one.
I'm fine with motors but dont do boxes
