hi
I'm looking for polycarbonate 'plastic' windows for a track mini.
Can anyone recommend someone, also some rough prices
Polycarbonate Windows
russ_1380
, May 25 2008 08:44 PM
4 replies to this topic
Posted 25 May 2008 - 08:44 PM
Posted 25 May 2008 - 11:30 PM
www.plastics4performance.co.uk i think is the website, off the top of me head its about £125-£150 a set.
Posted 26 May 2008 - 10:03 AM
cheers matey
Just needed to know the going rate to check I wasn't getting ripped off.
When you fit them, it looks like they just rivet on. Is a sealant used to stop water coming in?
Posted 26 May 2008 - 10:06 AM
cheers matey
I guess thats up to you, I would probably put a layer of silicon sealant around, then use a knife to tidy it up. Or you could probably get a roll of rubber like they used on the standard rear side windows.
Just seen you drive a Minus too, are there pics somewhere?
Posted 26 May 2008 - 12:33 PM
Hi mate
I'm on the mini minus register, I'm number 34 (Russ)
Not much to see yet as (well you can see from the pics) i got my work cut out!
I'm only in Merseyside but work in Manchester would you be able to offer some help regarding radiators and engine mounts sometime? I'll buy you a beer.
I have not yet found another Minus owner to share some tips with. Ideally I'd like a flat bonnet, no bumps but I doubt it will happen with the 7port
Russ
Russ
