HELP!,,
I have bought a new dash... looks very similar to every other type with 3 clocks infront of driver, 3 gauges with stereo underneath, glovebox and airvents of course!
Problem is... it came with 3 brackets ... one for the middle and one for each side... and they are all different lengths! As far as I can tell they clip behind the dash rails...
can anyone remember who has such a dash, which order the brackets go in? i.e. bigger bracket in the middle, shortest on the left, middle on the right?
Many thanks
TML
dash
themanlegend
, May 25 2005 08:44 AM
4 replies to this topic
Posted 25 May 2005 - 08:44 AM
Posted 25 May 2005 - 09:40 AM
I got the same brackets when I bought my dash from P&L. I've only got a backet on each end and not bothered with one in the middle. I just played about a bit and the brackets that fit best on each side, then bolted it all together. Holds the dash great with just two brackets holding it tightly in place.
Hope this helps,
Jam2005 :grin:
Hope this helps,
Jam2005 :grin:
Posted 25 May 2005 - 11:07 PM
Posted 26 May 2005 - 02:38 PM
small one is the passenger side one, the large one is the middle and the other one is for the drivers side!
Posted 27 May 2005 - 09:55 PM
cheers
