Mayfair Rebuild
#46
Posted 05 June 2009 - 04:20 PM
#47
Posted 31 July 2009 - 07:30 PM
I have welded in the hinge panel
Also got a corner repair panel in and ground the welds down. They still need a bit more but its getting there
I bought a non genuine rear quarter panel with the idea of see how it fits, if its not great then just use the bit where the window sits as thats the problem with the one on the car atm. For a non gen panel I`m quite surprised at how it fits so today I made a big hole:
Will split all the seams in the next couple of days and then see how it really fits
#48
Posted 02 August 2009 - 04:09 PM
I did find a nasty surprise in the rear bin though:
Has anybody got any tips on how to split the vertical seam by the door?? I don`t want to make a mess of it.
#49
Posted 02 August 2009 - 04:21 PM
A quick tip for welding.. when you're going in a line zigzag up and down a bit, gives a much better weld
#50
Posted 02 August 2009 - 05:42 PM
Only one way to get confidence is to give it a go
#51
Posted 03 August 2009 - 11:27 AM
Just need to tidy it all up and split the rq to rear panel seam and then I can fit the new rear quarter.
#52
Posted 03 August 2009 - 05:29 PM
#53
Posted 06 August 2009 - 08:05 PM
#54
Posted 13 August 2009 - 08:24 PM
I should be receiving two inner and outer sills from minispares tomorrow along with a few other things. I have cut most of the rust out now just want to get the new one`s before I go any further. I`ve already put a floor pan in the front so I`m using a inner sill repair panel to go from the cross member to to the heel board.
Tonight I`ve been messing around with the door that was repaired, the filler still needs some work but its getting there.
Oh and the rear quarter doesn`t fit as well as I first thought so thats going to be fun to fit
Thanks for looking, any comments more than welcome.
#55
Posted 18 August 2009 - 07:07 PM
cheers alex
#56
Posted 16 December 2009 - 04:05 PM
How's it going now? What colour do you have planned when it's all rust free?
#57
Posted 16 December 2009 - 05:26 PM
i have an 89 mayfair too and it seems its rotted away in exactly the same places, was the rot all hidden by filler? if so we might of bought them off the same person lol
#58
Posted 16 December 2009 - 06:09 PM
#59
Posted 16 December 2009 - 10:02 PM
Looks like yours was in a worse state than mine but you've got loads more done than I have, I've got some catching up to do it seems!
#60
Posted 28 March 2010 - 05:37 PM
Looks wicked in the first picture! Shame nice paint and oversills hide all that rust!
Well I`m finally back at it after about 6 months off, enjoying it again so its all good, hopefully make progress pretty quickly. I`m going with grey and black as it was before but I haven`t quite decided on the shade yet.
just read all the way through and i gotta say good work and progress
Cheer mate. I had some bits hidden by filler but not that much to be fair. How are you getting on with yours?
Well this week I`ve been back in the garage now its warmed up a bit, I found some motivation and set myself a target of 3 months to get the bodywork pretty much complete.
I`ve mainly been tidying bits up where it has developed little bits of surface rust over the winter and on getting the inner sill sorted:
Need to weld some plates on the outer sill then that can go on. Anyone know why there are holes either end of the outer sill? Its a genuine panel. Not using the jacking point so going to plate over that as well.
I also tidied up the rear bin before I put the rear quarter panel in:
