Idle Speed
7 replies to this topic
#1 Pooky
Pooky
  • 5,691 posts
Posted 25 May 2005 - 01:59 PM
What is the difference between the idle speed and fast idle speed? What do your mini's idle at?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 May 2005 - 02:12 PM
The idle speed is what the engine runs at when the choke is in, when you pull it out, that's the fast idle....
normally a well maintained mini will idle somewhere between 600 and 900 the older they get the less 'happy' the car is to idle slowly... when you start tuning and putting hotter cams in and such like the idle becomes lumpy, and hence it will need to increase to compensate...
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 May 2005 - 04:30 PM
Regardless of engine age/condition, the idle speed is typically happier with a little higher RPM if you're running anything other than a stock cam. My worn out 1275 would idle very smoothly at 600 RPM with its stock cam. I bumped this up to about 900 when I installed the SW5 cam.
#4 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 25 May 2005 - 07:03 PM
any problems with running a high idle, eg 1500rpm, apart from fuel consumption?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 May 2005 - 08:53 PM
Yes, you won't be able to drive any slower than about 15-20 miles an hour which is not ideal in traffic. As a result you'll wear out your clutch faster.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 May 2005 - 09:03 PM
You'll probably have dieseling (run on) with an idle speed that high.
#7 Pooky
Pooky
  • 5,691 posts
Posted 26 May 2005 - 08:34 AM
My mini's sometimes not happy idling at all. Sometimes it gets very lumpy on acceleration and can nearly stall at traffic lights etc...it does also run on a bit too, violently sometimes.
Also, is it true that a hot exhaust manifold can evaporate fuel in the carb? Could something like this be the problem?
#8 themanlegend
themanlegend
  • 244 posts
Posted 26 May 2005 - 09:13 AM
I found that using lead replacement my car ran on really badly... but seems as though my local tesco is stopping LRP that I will have to use it again. Although I realise LRP is supposedly 'C**p' the car doesnt run on.
If its not happy idling you could have a bit of wear in your carb - a refurb kit for 40 quid would sort this out of that was a problem. only a guess there.
