1.5:1 Roller Rockers
1275 SPRITE
, May 28 2008 08:23 PM
8 replies to this topic
Posted 28 May 2008 - 08:23 PM
Hi,
I have fitted 1.5:1 full roller rockers from Mini Sport to my 1275 head. Could anyone confirm the correct setting to adjust the valve clearances? Is this hot or cold adjustment?
Thanks.
Thanks.
Posted 29 May 2008 - 08:55 PM
Hi mate always set the clearances when engine is cold.Hi,
Thanks.
Posted 29 May 2008 - 08:58 PM
Also set them at 15 thou as i did with my roller tip rockers.
Posted 29 May 2008 - 08:59 PM
They should be 12 thou shouldn't they?
Posted 29 May 2008 - 09:02 PM
Isn't that for standard rockers these are hi lift, that's what advice i was given when fitting mine.
Thanks, I will try both and see which seems better.
Posted 29 May 2008 - 09:13 PM
Also mate when setting clearances slide the feeler guage from side to side,not in from the front
like on standard rockers,Good luck.
Posted 29 May 2008 - 09:14 PM
normal rockers are 1.2:1 ratio if your rollers are 1.5 then you need a proportionally bigger gap - your allowing a clearance for the cam followers with zero valve lift and expansion of the pushrods. For most factory original cams the clearance is 12thou so easy to work out you'd need 15thou with rollers. Check the spec for your engine/cam in your Haynes or cam fitting docs though.
Move your feeler blade side to side to check the clearance on roller tips.
Posted 29 May 2008 - 10:00 PM
12 thou, if your engine is cammed the cam manufacturer will provide a clearance.
