My Mpi Keeps Blowing Fuses
Posted 02 June 2008 - 06:31 PM
i have had a quick search and not found anything
My 1999 paul smith seems to be blowing its fuses out, it started last sunday when it was absolutly pouring with rain i was driving home, and on the busiest roundabout it could find it decided to blow rightmost of the four engine bay fuses out. once i got it home i gave all of the fuses a good clean replaced the blown one and carried on as normal (assuming the rain had caused a short, it ran absolutly fine for a week and then i too it into town tried starting it and the engine turned over fine but it would not catch so i got out and gave all of the wires around the ecu and coil pack a good wiggle, got back in and it started straight away, i went to pull out of the parking space and it died having blown the same fuse as before i went to the local auto factors grabbed another fuse (40a instead of 30 it was all they had!) put it in and it blew that straight away so i got towed home for a second time that week! not great considering its only been my daily driver for 2 and a half weeks!
any ideas?
Reuben
Posted 02 June 2008 - 08:50 PM
Hi guys
any ideas?
Reuben
Hi Reuben....I had a similarish problem a few years ago....It turned out to be a wire that emerges out of a 'plastic block' ( sorry - no idea what its for...) just above expansion bottle. It had been rubbing away against the underneath of the bonnet and ending up shorting out on one of the ribs (left a nice black burn mark on the paint).....I repaired the sheath and put a bit of hose over it to give a bit more protection. I've attached a photo showing you where it is........Might be worth a check before doing anything else....fingers crossed !!!!
Edited by miniboy1971, 02 June 2008 - 09:15 PM.
Posted 03 June 2008 - 12:18 AM
I would agree that if the car drives well when the fuse is replaced but blows after a journey, it is most likely a shorted wire. Fix it before i starts a fire
Posted 03 June 2008 - 01:10 AM
but to help out, is the wiring in good cond? I brought my mini and it had lots of bodge jobs that was causing the fuses to randomly pop. Slowly getting there with fixing everything but yes, check all the wiring is done well. Like above said, check for frayed wire to.
Posted 06 June 2008 - 12:26 PM
