Brand New Engine Number Plates
23 replies to this topic
#1 orchard-engineering
orchard-engineering
  • 14 posts
Posted 03 June 2008 - 10:28 AM
Hi there all..... i`ve been involved with mini`s for many years,but I recently have started maching a totally unique replacement engine number plates and rocker covers and just about anything that you might require to customize your mini..... i`ve also done a dash for my mini.... see attached pictures
if you can think of something that i might be able to help you with, then email me and i`ll try my best to help you
i have also done for my own mini a totally unique engine number plate to replace the engine number plate after the block is skimmed, which fits into the original rivet holes, and can also have just about ANYTHING on them as long as it will fit prices will start at £10.00 each depending on what you require on it
I also have started doing one off rocker covers that are new aluminium castings and i am able to machine just about ANYTHING on the top and if you want the front of the cover, that you can think of, making it totally unique to you....... i try to design it so that the middle of a letter/image will unscrew to allow the oil to be put into the engine without ruining the design (if you look closely at the picture your see the middle of the "O" will unscrew to fill up the oil.......i`ve done many others with a simular ideas ...email me and i`ll send you a few sample pictures of previous jobs i`ve done..........
They are brilliant and i aim to be 100% helpfull to all my customers ensuring that all my customer are getting exactly what they want , they even have a small lip around the bottom to hold the rocker cover gasket in place to stop in falling into the where the rocker shafts are, which a std. rocker does not have but could do with.......
my email address is .................. [email protected].... please contact me via email as i will then have your address to email back a design for you
If your interested then get in touch, prices start from £65 for your one off rocker cover.... i can email you a mock up picture of what your cover will look like, so you know what it`s gonna look like before you order and also a price, just give me a rough idea of what you`d like
thanks and best of luck
Brian
Edited by orchard-engineering, 25 June 2008 - 07:39 AM.
#2 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 15 June 2008 - 09:21 PM
When I saw these I thought that they looked very individual, so, decided to order one. I have to say Brian is a top bloke, very friendly and keeps you up to date on what is happening to you item.
The machining work is top notch and when it turned up it was well pakaged.
will up load a pic shorltley but anyone that was thinking about it, all I can say is DO IT, you won't be dissapointed.
Edited by BoboGib, 15 June 2008 - 09:24 PM.
#3 lewis
lewis
  • 2,322 posts
  • Local Club: Mini Club Jersey
Posted 15 June 2008 - 10:01 PM
how much on average is one of your engine plates? there mint!
#4 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 15 June 2008 - 10:05 PM
could you re-create this with a hidden oil filler cap? and how much please :thumbsup:
studio max / rhino files available ready to straight to CNC
#5 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 15 June 2008 - 11:15 PM
He charged me £10 incl postage for mine, would imagine around the same. prices couls vary slightly depending on what you want but he is a top bloke, can't imagine he would charge way over the top.
#6 jack_marshall
jack_marshall
  • 2,540 posts
Posted 15 June 2008 - 11:35 PM
That is cheap!
#7 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 16 June 2008 - 06:47 AM
Not being funny here, but doesn't the engine plate have to have the engine number on it?
#8 Flippy
Flippy
  • 293 posts
Posted 16 June 2008 - 03:03 PM
how do you top the oil up, just with a funnel??
Edited by Flippy, 16 June 2008 - 03:19 PM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 June 2008 - 03:24 PM
Where in the world (UK) are you Brian...
#10 joe_m
joe_m
  • 1,240 posts
Posted 16 June 2008 - 09:33 PM
how do you cut em >
lazer cutter ?
#11 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 16 June 2008 - 09:48 PM
He is based in the gloucester area
#12 orchard-engineering
orchard-engineering
  • 14 posts
Posted 17 June 2008 - 08:11 AM
i`m based in Cheltenham... and all of the jobs are done mostly on a cnc milling machine although i do have a small workshop with a milling machine and lathe........... i`ve just started up this small business and i`m getting alot of enquiries at the moment, just hope they all turn into work for me??..... at the moment i`m able to keep my prices down as i have little overheads and i`m also working full time and doing this as a part time venture at the moment but would love to be able to this sort of thing full time as the variety of work i`m getting asked to do is very interesting..... hope to hear from more potential customers soon....
. i can be contacted on [email protected] or you can ring me on 07901712988 AFTER 4PM
thanks Brian
#13 orchard-engineering
orchard-engineering
  • 14 posts
Posted 17 June 2008 - 08:15 AM
with any of the rocker cover i do, the oil goes in a desctreet hole in the top (normally in the middle of a letter/number), the size of the hole is dependant on the design, but the holes i have produced up to date range from 20mm diameter to 32mm diameter, but really anything is possible
#14 lewis
lewis
  • 2,322 posts
Posted 17 June 2008 - 04:30 PM
ahh but thats when i use the design as a plaque instead :unsure:
#15 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 17 June 2008 - 08:10 PM
I thought that if you built your own egine to a different spec then the engine number was no longer valid anyway.
So as far as im aware you can make up your own engine number, inform the DVLA about it, and have your V5 document changed accordingly. Ifim right about this then you could have one of these cool plates with your engine on in cool writing?
Edited by Stewart_GT, 17 June 2008 - 08:10 PM.
