Mini Sidewalk - Windscreen Removal
8 replies to this topic
#1 RobinHood1
RobinHood1
  • 10 posts
Posted 06 June 2008 - 09:09 AM
:( Hi First of all a big Thank you to everyone who helped with the problem I had with the suspension on the mini. All sorted.
I am going to have some bodywork done on the car and it needs to have the windscreen removed. I have been told that I will need to have a special tool to remove the silver trim that surrounds it.
Can anyone tell me what this tool is called and where to get hold of it.
Thanks in advance.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 06 June 2008 - 09:20 AM
No tool required for removing, should be a metal clip near the top, flick this out with a small screwdriver...then just use screwdriver to pull the first 1" out of the trim, then just carefully pull it out..
You do really need a windscreen insert tool for putting it back though, minispares sell them, but you can get a better one with a roller on it, just can't find a link
found it
http://www.frost.co....?productID=8104 pretty expensive though
The minispares one
http://www.minispare....aspx?pid=37420
Edited by lrostoke, 06 June 2008 - 09:23 AM.
#3 RobinHood1
RobinHood1
  • 10 posts
Posted 06 June 2008 - 09:29 AM
:( Many thanks for your help.
#4 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 06 June 2008 - 10:04 AM
You don't NEED a filler strip tool - I use a very blunt old screwdriver, some fairy liquid, a steady hand and patience. Filler strip tool does make it a lot easier though.
Silver semi rigid trim is a lot easier to work with than the flexi black version.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 06 June 2008 - 10:09 AM
First one we did we used a screwdriver, what a ball ache :( we've got the cheaper minispares tool, and last one we did was a doddle, like you say fairy liquid helps loads
Another thing we just tried as well and seems to be working, bro in laws seal used to leak slightly (new seal) , so when we just had to change a chipped screen we smeared vasoline around the window frame before fitting the rubber..so far no leaks
#6 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 06 June 2008 - 11:10 AM
surely fairy liquid bubbles for a bit, and the salt is corrosive? I know it works, was just wondering if anyone's tried baby oil?
#7 Juju
Juju
  • 3,620 posts
Posted 06 June 2008 - 11:16 AM
If you want to lube/waterproof a rubber seal, then you should always use a non-oil-based product....as all decent Family Planning Clinics will tell you. :(
#8 Lacuna
Lacuna
  • 123 posts
  • Local Club: Bournemouth / South Coast
Posted 06 June 2008 - 11:24 AM
Yea, I've also been advised against using washing up liquid because the salt will attack the windscreen...
~ Lacuna
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 06 June 2008 - 11:33 AM
I wouldn't worry about the salt in it, doubt theres that much in it, and your car probably gets subjected to far worse from road salt.
Besides when we recently removed a windscreen that was chipped, the metal work and screen looked fine, and we'd fitted it 2 yrs previous using washing up liquid.
Just tried a search about it, MG Owner club even have a page about fitting screens which says use washing liquid
http://www.mgcars.or.../mgbgtwind.html
Not saying its right though :( :)
Edited by lrostoke, 06 June 2008 - 11:36 AM.
