Juddering In 3rd And 4th Gear
12 replies to this topic
#1 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 07 June 2008 - 02:22 PM
hi
recently i have been getting alot of bad juddering in 3rd and 4th gear when i start to accelerate, what causes this and how can i fix it?
its when i let of the accelerator and then push back on
cheers
ncik
#2 Ethel
  • 26,187 posts
Posted 07 June 2008 - 02:28 PM
Depends,
Could be engine steady 'n mounts if it's more of a clunk, or it could be your clutch.
#3 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 07 June 2008 - 02:37 PM
just had engine mount changed so wont be that, not the clutch , the juddering is happeneing when i try get speed and the speed takes ages to kick in if you get me
#4 Rhys
Rhys
  • 898 posts
Posted 07 June 2008 - 03:48 PM
Still sounds like slipping clutch to me, could be a problem with airflow as well, have you changed anything like that recently?
Rhys
#5 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 09 June 2008 - 01:46 PM
maybe but from what i can tell its not the clutch as i dont even have to touch the clutch to make it start juddering its just as i accelerate from say 30mph in 3rd and 4th the car just jumps and judders forward feels like a back fire if you get me
#6 Rhys
Rhys
  • 898 posts
Posted 09 June 2008 - 05:43 PM
Is this when its warm and cool?
Rhys
#7 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 09 June 2008 - 08:46 PM
cool, when the engines warm its fine but can occur at times
#8 minicooper1.3i
minicooper1.3i
  • 878 posts
  • Local Club: na
Posted 10 June 2008 - 08:00 AM
I'm with Rhys on this one. Sounds like you've got a contaminated clutch plate, maybe from a faulty primary gear oil seal. My brothers suffererd from a lot of clutch judder after changing his clutch and seal (without using the proper tool).
I've also got a very similar problem on my scenic, which I'm thinking is the clutch too.
#9 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 10 June 2008 - 09:55 AM
its so annoying because when u want speed it takes a while till you even get some, not the safest thing
#10 Ethel
  • 26,187 posts
Posted 10 June 2008 - 10:12 AM
It is a hard one to diagnose without seeing the car. It could be an ignition (sticking advance) or fuel (lean out) issue but you'd expect it to happen in all gears. It could just not be noticeable in 2nd because it's a higher ratio.
The clutch still seems likely, the higher the gear the greater proportion of the car's mass the engine and clutch will see per revolution. Try slowly pressing the clutch next time it happens the clutch should disengage very easily if it is slipping.
Edited by Ethel, 10 June 2008 - 10:13 AM.
#11 minicooper1.3i
minicooper1.3i
  • 878 posts
  • Local Club: na
Posted 10 June 2008 - 08:19 PM
The other way to check the clutch is to park up, put the hand brake on, put it in gear and slowly let the clutch out. If the clutch is fine then the engine will labour and eventually stall. If not, then the clutch will slip. If the juddering is worse when it's cold it 'could' be because if it's contaminated with oil and dust (from the clutch) then when it's cold the contamination is going to be 'slimey' and lumpy, but as it warms up then it will become more like an oil and slip more freely ie. less juddering.
Not pretending to be an expert on this, just speaking from personal experience. But do the test I've suggested above on a hot engine and see how hard the engine works to move the car.
Let us know how you get on :P
#12 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 11 June 2008 - 12:29 PM
ok cheers guys will give these a go
#13 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 13 June 2008 - 09:07 PM
i found the problem with the juddering it was the points had started to close up, my dad opened them up again and the car runs so smooth now, cheers for trying to help guys.
