Flasher unit location?
9 replies to this topic
#1 Neil Clark
Neil Clark
  • 74 posts
Posted 01 June 2005 - 10:29 PM
Wheres the flasher relay on a H reg mini?
Cheers!
#2 Jackman
Jackman
  • 4,053 posts
Posted 01 June 2005 - 10:30 PM
Well if you mean indicators then mine was on top of the steering column.
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
which one lights , hazard or indacators
#4 evolotion
evolotion
  • 26 posts
Posted 01 June 2005 - 10:34 PM
i take it your changeing it??
early 80's minis had them on the bulkhead. <for reference :cry:
if so can i recomend a wee upgrade? if yours is the metal can type they break lots(wel mine did) you can upgrade to a timer controlled relay (as used in modern cars). If you go into halfords and look at flasher units, there is the usual metal ones and some black plastic ones. find a black plastic one the same rating as the metal one you need and look at the card on the back, you want one with 3 connections and it will tell you on the car which number = "B" which number = "L" and which number is the earth.
wire it up as-per your old flasher and supply an earth to the pin it says.
jobs a goodun, mines has suffered 2 years of daily use and not failed once, in the 2 months previous i went through ~4 metal cans :cry:
HTH
#5 Neil Clark
Neil Clark
  • 74 posts
Sorry, silly me, HAZARDS!
Found the indicators ok...
#6 Neil Clark
Neil Clark
  • 74 posts
Posted 01 June 2005 - 10:49 PM
Am after the hazard relay, any ideas people?
Cheers! :wink:
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 June 2005 - 10:50 PM
Hazard relay is by the wiper motor on the engine bay
#8 Neil Clark
Neil Clark
  • 74 posts
Posted 01 June 2005 - 10:56 PM
Silver square metal one with just 2 wires?
#9 RacingGreen
RacingGreen
  • 2,111 posts
Posted 01 June 2005 - 11:09 PM
yeah, thats the one.
#10 Neil Clark
Neil Clark
  • 74 posts
Posted 01 June 2005 - 11:10 PM
Sound, its completly knacked!
Thats why it failed MOT then....
LOL, will go scrapyard over weekend
