Carbon Fiber Gel Coat/pain Splintering
5 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 16 June 2008 - 03:59 PM
Well im been offered a carbon fiber bonnet, but the paint has splintered, so im guessing this is down to a problem with the gel coat that has then effected the outer pain....
So my question is what is the cure to this problem? would i just rub it back and paint as normal, or will the splinering just re-occure?
#2 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 16 June 2008 - 04:13 PM
Proper etch primer is required, otherwise paint won't stick properly to laminates.
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 16 June 2008 - 04:14 PM
No its not that its the gel coat that has cracked and this has caused the paint to crack.... Etch primer was used.
#4 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 16 June 2008 - 04:21 PM
I've not come across carbon fibre with a gelcoat, but gelcoat crazing is common in GRP - my bonnet below has some of the cracks ground out, but many still to go.
you need to grind off the offending gel areas and reapply or fill.
#5 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 16 June 2008 - 04:26 PM
Cheers, so it would need to be taken back to before the gel coat and then filling, then painting.
#6 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 16 June 2008 - 04:30 PM
Pretty much yes, but it's a good idea to grind down, one new layer of fibre and resin, then a slight skim of filler over the top - this way, if the crack goes into the fibres it gets sealed back in.
