due to a freak minor accident I recently manged to slice the cable for the oil pressure sensor, soldered a repair and all was good.
tonight engine has gone a bit jerky, couple of minor back fires and will only rev if you let the gas on slowly and gently.
question 1. is it safe to assume the repair to the cable wasn't done well enough and this might be causing the problem ?
question 2. is it safe to assume if I remove the oil level sensor, oil will gush everywhere ?
for the sake of swapping a 4 quid part am I gonna have to drain and refill 40 quids worth of oil ?
thanks
martin.
PS, no section in motorbike conversions so I have to keep coming into the big boy's playground
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/thumbsup.gif)
