Blanking Bypass Hose
Posted 16 June 2008 - 10:44 PM
Posted 16 June 2008 - 10:59 PM
I thought even non bypass pumps still had the pipe cast in, it just isn't drilled? The pipe in the head is screwed in so you could possibly replace it with a tapped plug (rust permitting) as they did with the A+ Metros...
or you could do as you suggest
Posted 17 June 2008 - 01:16 PM
Yes you can but still need some form of bypass, I suggest drilling the thermostat, search to see where this should be done.My new head has a bypass hose doodah, but my new water pump doesn't. I can't be bothered to buy another pump with the bypass, so can I safely just blank off the head bypass with a length of hose and fat bolt jubilee clipped in the end?
When you put the bolt ina little glue or gasket sealant doesn't hurt either.
D
Posted 17 June 2008 - 01:49 PM
Posted 17 June 2008 - 03:41 PM
You must have so sort of by-pass. This is what I have done:
Holes should be about 1/8" or 3mm (or less)
Posted 17 June 2008 - 05:48 PM
Posted 17 June 2008 - 07:16 PM
Can you not buy a metro thermostat, becasue that will aleready be modified surely...
no the metro has a sandwhich plate design which has the heater take off, this performs the bypass function, also why there is no heater take off on metro lump heads.
Try drilling water pump If you can't then you will need a blanking sleve to replace stat in cyl head .................
no you don't, see above post above, just drill some holes around the thermostat edge.
i would get a proper screw in bung
Posted 17 June 2008 - 09:50 PM
Posted 18 June 2008 - 07:44 AM
Not sure, but I agree with the above comment, blank the water pump, and drill the thermostat, I tend to put two or three holes in about 5mm each, as I think that about matches the diameter of the bypass hose, I did work it out once... Anyone know the bypass hose internal diameter?So why does my cooper head have a pipe that attatches to the water pump, but it has the sandwich plate on the thermostat?
Dave
Posted 18 June 2008 - 01:11 PM
i believe its because the mini has a valve in the heater feed to vary the heat, the metro has the heater
under the bonnet permanently on (no valve, the heat is varied by air flow though the heater matrix)
this means when the valve is closed there would be no bypass
i believe the only minis without the bypass hose are the mpi's, not 100% sure on that though never really looked
