Heater Vibration!
Posted 17 June 2008 - 10:41 AM
i'm considering taking the heater apart to have a look and was wondered if anyone has managed to fix this in the past, and what they might have done
i guess it is the 'flap' which directs air either to the car or screen - but it's hellish noisy when it vibrates like it does!
thanks
james
Posted 17 June 2008 - 03:38 PM
i'm not really looking forward to taking it apart so any 'education' on this would be good
thanks
Posted 17 June 2008 - 04:01 PM
check under the front of the heater....
you should see two rivets that hold the workings of "the flap" in place.
one of mine was missing, quick and easy fix without having to take anything apart.
if its not this then look for any other missing rivets or strange holes that have nothing in them
Posted 03 July 2008 - 07:58 PM
Posted 04 July 2008 - 09:24 AM
will have to check if anythings missing.
Bb
Posted 04 July 2008 - 12:35 PM
Edited by minicooper1.3i, 04 July 2008 - 12:36 PM.
Posted 04 July 2008 - 12:55 PM
Use a bowl to catch the run off from the hoses, you then just need to undo 2 screws holding it to the dash rail and slacken and unhook the nuts at the rear. Unplug the loom from the switch, pop the air hoses off and you can lift it out.
Posted 06 July 2008 - 05:08 PM
Posted 06 July 2008 - 05:58 PM
Posted 06 July 2008 - 06:09 PM
yeh, i removed it to have a look. i've decided not to take it apart, but running without it is fantastic. it's so much quieter! i'm leaving it out until until i feel i need it
join the hoses rather than block them. The heater is little more than a box refurbishing is easy enough too.
Posted 06 July 2008 - 09:11 PM
Don't want to be a spoil sport but isn't that an MOT failure? I'm sure there's a requirement to be able to de-mist the windscreen (or is that on the the SVA test?).
Posted 07 July 2008 - 06:24 AM
