Mot Failure! :(
Posted 18 June 2008 - 05:53 PM
1) Windscreen washers - I'll have to make sure they're not blocked, no problem.
2) Exhaust blowing - The exhaust system is really rusty and I thought I had patched it up ok with Gun Gum, but I accept it needs replacing, so I'll give them that one too.
3) Apparently the front panel isn't welded to the inner wings and it's within 30cm of structural mountings.
It's the number 3 that I'm not happy with. My sister had a crash a few months ago and we left it to the insurance company to sort out this time. I've been a bit unhappy with a few areas of paintwork... but now it looks like they havn't even done the welding properly! We will of course be taking it back to the body shop asap to have words with them, but...
...I'm assuming it's the tabs of the front panel that havn't been welded to the inner wings (I havn't yet had time to look and won't until the weekend). Surely that's not near anything structural? The whole front end isn't structural as a mini will happily drive along without a front end. Therefore I think the garage have unfairly failed the mini on that point.
Are you with me on this one??
Posted 18 June 2008 - 05:56 PM
Posted 18 June 2008 - 06:04 PM
Posted 18 June 2008 - 06:13 PM
It needs sorting out! And the bodyshop should sort it out for you without a problem if you approach them in the right manor.
Posted 19 June 2008 - 02:10 AM
Surely the mounts are for the subframe to support the front panel not for the front panel to support the subframe?
well technically the mount is there to support the subframe and keep the sub frame attached to the car. as pointed out earlier if you do a flip front then you need to add brace bars in to keep the structal support. hope this is any use. the bodyshop that repaired the car must return it to road worthy condition. so they must sort out the welding as the car is technically not road worthy.
sorry if my spelling is rubbish
matt
Posted 19 June 2008 - 04:55 PM
Posted 23 June 2008 - 01:11 PM
Id say well done to the MOT guys for spotting it.
I agree man, I know it failed which is always a bummer, but, if they hadnt of found that, would you of? you could of been driving around with a bad welding, so in some ways they have done you a favour, and I am positive the body shop will sort it for you. Its only been a little while since they did it, and it failed on the bodywork they sorted (supposedly), so ur be fine
Best of luck
Posted 23 June 2008 - 01:31 PM
Posted 23 June 2008 - 09:53 PM
I've ordered up a complete exhaust system which consists of a Maniflow manifold and RC40 backbox...lucky next owner!
Then after I've got that fitted I'll get it back to the bodyshop for them to sort things out properly.
I won't want it sell it after that's done!
