Mk3 To Mk1 Grille
Posted 20 June 2008 - 09:38 PM
I'm building a modern/retro Mini project and I can't help looking longingly at that Mk1 moustache / grille.
How big job is it to change the front of my '88 car and fit a moustache ?
Best wishes
Monty
Posted 20 June 2008 - 09:45 PM
The Mk1 bonnets have the mounting plates closer in on the inside so maybe you will be able to Mod it or you can just buy a Mk1 style...
Posted 20 June 2008 - 10:01 PM
Posted 21 June 2008 - 07:39 AM
Posted 04 May 2009 - 12:38 PM
Posted 04 May 2009 - 12:42 PM
The Mk3 bonnet makes up part of the Mk3 grille.. so if you want to change the grille to MK1 you need to take the lip of the MK3 bonnet.
Edited by theIMAGE, 04 May 2009 - 12:42 PM.
Posted 04 May 2009 - 07:58 PM
Posted 04 May 2009 - 08:02 PM
Mm he did Yeti & MK1 bonnets are different to MK3.
ok so to change my grill etc to mk1 i need to take the chrome bit off and drill out the spot welds and then it will fit properly???
YetI
Posted 04 May 2009 - 11:16 PM
with pliers you won't need to do much drilling... : )
To get a good finish you should drill though. Then maybe fill and paint. I didn't bother because I knew I would replace the bonnet
(which is sad and sorry) anyway but if you're is OK I'd say do it "properly".
Have you alreaady got your MK1 grillle and 'tash ?
If not, I'd advice checking out what they cost because new they are big bucks, on eBay they go for between (rusty) £40 and (mint original) £100.
And that's each - not as a pair and you need both for the look.
My poor old bonnet has rust and the scars of battle - if anyone near Birmingham has one (of any vintage) that needs
a good home please PM me...
Best wishes
Monty
Edited by MiniMonty, 04 May 2009 - 11:24 PM.
Posted 05 May 2009 - 01:57 PM
Hi all,
Best wishes
Monty
There is a guide to doing this in this months mini magazine
Posted 07 May 2009 - 11:03 AM
