Why Is My Headlight Switch So Hot
12 replies to this topic
#1 Doodle
Doodle
  • 314 posts
Posted 22 June 2008 - 10:37 PM
I burnt my finger removing the headlight switch earlier on after i had just been out for a drive..its still stinging now! i wasnt expecting it to be hot
i thought i'd check the switch becuase my instrument lights are not working, just thinking that the switch has quite a bit to do with that now
why would it get that hot? is it something switches do when they break? if its hot enough to burn me i would think its also hot enough to melt and set on fire too :S
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 22 June 2008 - 10:46 PM
check the all the earths are secure and operational :gimme:
#3 Doodle
Doodle
  • 314 posts
Posted 22 June 2008 - 10:56 PM
:gimme: thanks, where do i find them? is there specific points in the interior of the car that the electrics are earthed to?
#4 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 22 June 2008 - 11:09 PM
It could've been that the multiplug in the back wasn't pushed RIGHT into the back of the switch. I've had one burn out before because of that.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 22 June 2008 - 11:46 PM
Old wiring, extra lamps or a Halogen conversion and the carpiness and low-spec of the OE switches cause this. The headlamp circuit current is dangerously close to the switch rating as standard so any of these changes can overload it. It's common and there are many threads about melting headlamp switch wiring. It can indeed cause a fire. Firstly find out if anything is directly causing an overload and if so fix it, this could be due to something like a headlamp wire contacting a steel headlamp bucket. If there seems to be no problem then it is probably due to a buildup of corrosion throughout the wiring and short of fitting a new loom or re-making every end in the one you have the best option is to fit relays into the dip and main circuits. Then fit a new headlamp switch and plugblock for it because these have probably been damaged by the heat.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 22 June 2008 - 11:55 PM
I second Dan's comments.
There is an alternative to the new loom however. You can build and install your own relay panel for the high and low beams using standard ISO/Bosch relays. The intent here is that your existing wiring will trigger the relays instead of powering the headlamps directly. The relays will make a direct power connection to the hot stud on the starter solenoid and each relay will have its own inline fuse from the solenoid connection. This reduces the current passing through the dash switches from several Amps to less than 100mA... a tremendous change.
#7 Doodle
Doodle
  • 314 posts
Posted 23 June 2008 - 06:16 PM
Thanks guys, i do have a halogen conversion..that could be responsible, but i'll take the lights out and have a look for any damaged or lose wiring. both of my headlamps have plastic bowls, but there maybe a loose wire touching something it shouldnt
I'm interested in the relay idea, what would be involved with setting that up?
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 23 June 2008 - 08:23 PM
Over here, several British car parts companies sell relay kits just for this purpose. One, Advance Auto Wire, is going out of business after the death of the man who ran the company. However, his family has kept the web site open along with its schematics and technical information.
Please visit:
http://www.advanceautowire.com/
and on the home page, look down the left side of the screen and click on the link for "Headlight Relay Kit". There is a schematic there showing you what to do.
"To Power Source" would be the hot terminal on the solenoid. The relay terminal numbers are for the standard 30A ISO/Bosch type relay. The wire colors shown correspond to the standard Lucas scheme for the headlight wiring.
#9 Doodle
Doodle
  • 314 posts
Posted 23 June 2008 - 09:29 PM
Please visit:
Thanks Doug :(
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 June 2008 - 09:32 PM
Somewhere on here I did a pretty thorough description of how to install relays and fuses in the dip and main circuits including how to re-arrange the wiring. You should find it with a search.
#11 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 23 June 2008 - 10:17 PM
I could probably prepare a customised converion for folks not confident on wiring too....
#12 zeroasylum
zeroasylum
  • 378 posts
Posted 24 June 2008 - 08:32 AM
Please visit:
Thanks Doug :(
This will help you. http://www.theminifo...eroasylum relay
It helped me with the problem.
Zeroasylum
#13 1984mini25
1984mini25
  • 8,785 posts
Posted 24 June 2008 - 09:42 AM
It wouldn't be a sort in the headlamp/bowl, it’s because the halogen lamps are drawing more current than the standard sealed beam ones, which is overloading the wiring, causing it to overheat/overload the wiring and connectors, eventually leading to a toasted mini.
Dan, 10:32 PM
Below is my saved version of dans very helpful Headlamp wiring relays advice.
Since you say you don't have much experience with electrics, it's probably best to get two of the pre-wired relay and fuse kits that can be bought from places like Halfords. While you're there get some electrical tape, some cable ties, some blue sleeved 8mm ring / eyelet type crimp terminals and some male and female bullet type crimp terminals (Blue or yellow sleeved if you're getting the pre-insulated type, red would be OK but blue is best). You said you've done some crimping so I assume you have a crimp tool and can at least cut and strip a wire and crimp a fitting on.
Almost all the connections you are going to need already exist behind the slam panel, where the two headlamp assemblies are joined into the main loom using bullet connectors (he says, hoping that Clubman is the same as Mini in this department). These look like little rubber bricks.
Disconnect the battery earth cable from the battery, and put the cardboard cover back with the cable outside it so it can't fall back onto the battery.
Find somewhere to mount the two relays, like on the drivers side inner wing and bolt the two relays in place. If you can use holes that already exist then that would be best but if you really need to drill some, make sure you paint the edges of the cut with some touch up stick.
With the relays mounted and the fuse holders arranged so that you can get to them, you're going to start laying out the cables. Work with one set at a time so you don't get confused. Take three of the four cables from one relay and lay the wires along the wing and up to the bullet connectors, following the route of the existing harness.
Whatever colour the cable is that the instructions tell you is from pin 30 on the relay (probably red) is going to run straight down the wing with the other cables that run to the starter solenoid, the other three to the front panel. When you know how long each cable needs to be and you have got them running a tidy route, cut them to length but don't tie them into anything yet.
The pin 30 cable running to the solenoid needs one of the 8mm eyelet connectors fitted to it. The pin 85-cable needs a female bullet connector fitted to it and the pin 87 cable needs a male bullet. Leave the pin 86 wire for now.
Determine which of the bullet packs has blue/red cables running to it. This is the dipped headlamp connector. Determine which of the cables from this connector is coming out of the main harness rather than one of the lamp cluster harnesses and remove this cable from the connector. This is going to be the signal cable, which triggers the relay; it comes directly from the dipswitch in the steering column. If the cable pulls out and its bullet has fallen off, don't panic they do that, as they get brittle with corrosion. Put a new bullet on it and join it to the cable from pin 85 of the relay. Wrap this joint in some tape, three wraps is enough.
Push the bullet on the wire from pin 87 of the relay into an empty space in the multi bullet connector so that it joins to the two-headlamp cluster loom dipped beam cables. Make sure it clicks into place.
Now do the whole thing again with the other relay, using the connector block with blue/white cables. This is the high beam connector.
Now you should be left with the two pin 86 cables, which hopefully should be black. Join both of these by crimping them into a single male bullet connector and click that into the multi bullet block with black wires in the slam panel bundle. A bit of tape around the two just up from the connector will stop one being pulled away from the other which is a good thing to do when they are crimped together like this.
All that remains now should be the two ring terminals by the starter solenoid. Identify which terminal on the solenoid is connected directly to the battery and remove the nut from it, slip the rings over the top and re tighten the nut.
The kits should have blade fuse holder already fitted into them. If you have to fit them yourself, they need to go inline in these last cables fitted to the solenoid. They probably come with 15 amp blades. You should switch these for 10 amp blades. If they are glass cartridge fuse holders they need to be 25 amp cartridge fuses.
You should now have a nice tidy installation with the minimum of butchery to the car's original electrics and which can easily be removed if you ever need. Re-connect the battery earth and see whether the lights work in both high and low beam.
If everything is working, tape all your new cables up into a tidy auxiliary harness and cable tie the new harness on to the outside of the existing harness to keep it all tidy.
If it doesn't work, come back and tell us.
Dipped beam
30 = Red run to the starter solenoid with 10amp fuse
85 = Signal cable, which triggers the relay: blue/red cables, dipped headlamps
86 = Multi bullet block with black wires
87 = Joins to the two-headlamp cluster loom dipped beam cables
High beam
85 = Signal cable, which triggers the relay: blue/white cables, High beam
87 = Joins to the two-headlamp cluster loom high beam cables
Edited by 1984mini25, 24 June 2008 - 09:49 AM.
