Indicators Working But Not Flashing
9 replies to this topic
#1 pinkminigem
pinkminigem
  • 27 posts
Posted 25 June 2008 - 07:53 AM
Hey, its me again with another silly problem.....
My indicators are working but they are not flashing. I dont know whether it has anything to do with it, but ever since I bought the car, they have been flashing double speed, but Ive never owned a mini before so I just thought thats what they did :dontgetit: I havn't checked the hazards yet though, but they are seperate arent they?
Any help would be great but photos would be even better for a little girly such as myself who hasnt got a clue :cry:
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 25 June 2008 - 08:17 AM
It could be the flasher unit is duff, The indicator one is normally located inside the car on the drivers side, look in the dash or round the steering column...for a smallish silver thing with 2 wires coming out..
Looks like this
http://www.minispare....aspx?pid=34170
#3 analogue_radio
analogue_radio
  • 4,897 posts
Posted 25 June 2008 - 08:18 AM
Hazards & Indicators both have seperate units, one in the engine bay which will be the hazards and one in the cab of the mini which will be the indicators.
I can see Irostoke is on the case so I'll let him do the rest of the talking :cry:.
#4 pinkminigem
pinkminigem
  • 27 posts
Posted 25 June 2008 - 12:56 PM
ok will check when I finish work as it looks like my mini is winking everytime I turn a corner!! hehe. so would I just buy a new one to fix the problem? Can you tell just by looking at it if its broke? x
#5 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 25 June 2008 - 01:00 PM
Nope unfortunatly not. And ive tryed the shaking test before as well and had one that rattled and one that didnt but they both worked fine ;)
They are not that expensive so if you get one and thats not the problem then at least you have a spare.
You didnt mention what your hazards do. Are they working ok?
#6 Ethel
  • 26,073 posts
Posted 25 June 2008 - 01:03 PM
Stick your hazards on so you can check all the bulbs are flashing with equal brightness. If they are, then it probably is the flasher unit or the contacts on it. It's easier to replace it rather than try and test it.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 June 2008 - 01:24 PM
while you're there buy two, as the halfords ones are notorious for failing....
I've had one fail in less than 2 hours.
Converted to an electronic flasher, but now that's starting to play up, as everyone knows in my club when following me....
#8 pinkminigem
pinkminigem
  • 27 posts
Posted 26 June 2008 - 12:14 PM
I have checked the hazards and they are working however now the indicators have started flashing again randomly when they feel like it, and every now and again they are just on constantly. would it be just a dodgy flasher unit. I tried to look for it but couldnt find it :( maybe im just being blind
#9 whiskymac
whiskymac
  • 247 posts
Posted 26 June 2008 - 12:17 PM
I find the cause of this problem is usually rusty front indicators causing a bad earth connection - if you take the unit and clean it up it usually all works fine again - for some reason it doesnt seem to stop the hazards flashing, only the indicators!?
#10 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 26 June 2008 - 12:20 PM
I have checked the hazards and they are working however now the indicators have started flashing again randomly when they feel like it, and every now and again they are just on constantly. would it be just a dodgy flasher unit. I tried to look for it but couldnt find it :D maybe im just being blind
It will be behind your dash usually located behind the speedo unit. Its usually circular but i have seen some rectangular ones to. Your just gonna have to get down by your pedals with a torch looking up and have a root around. Also in the interest of safety im going to suggest you disconnect your battery first before you start rumaging around amounst all the wires.
The only other explantion is that someone had butchered your wiring in the past and has moved it to some completely different location :errr:
Edited by Stewart_GT, 26 June 2008 - 12:21 PM.
