hi there again...havn't been in this section for a long time
while driving home on motorway today the car began misfiring very badly so managed to nurse it under a bridge to avoid the rain and set about changing the coil..... 5 mins later we were back up and running and got home.
been out again tonight and went to put my foot down in 4th and it spluttered like before but then rectified itself and has run around and got me home again..... but got a bad feeling this coil isnt going to last too long
my car is a 998 1988 and is a ballasted system with the ballst coil on the output to the +ve side is 9 volts when running so there is not too much voltage going to the coil
any help would be much appreciated (scratches head vigorously)
Coil Problems
daryl_crossley
, Jun 29 2008 06:56 PM
5 replies to this topic
Posted 29 June 2008 - 06:56 PM
Posted 29 June 2008 - 08:14 PM
just been looking at the coil and it says ELECTRONIC COIL on it... i am not running an electronic ignition could this be the problem with it not running quite right
Guest_iansmini_*
Posted 29 June 2008 - 08:17 PM
Yeah that will be a problem you will probably have noticed that you will have been running a very hot coil. The electronic coil is 12v, you will need a ballasted coil as to comply with your ignition system 9v is the right voltage a mini with a ballasted ignition system.
Guest_iansmini_*
Posted 29 June 2008 - 08:19 PM
Just re-read your thread did you check the gap on your points and did rain get into the dizzy at all?
Posted 29 June 2008 - 08:29 PM
no rain on dizzy and points gap is bang on.... need a new coil then asap
thanks iansmini
thanks iansmini
Posted 30 June 2008 - 04:28 PM
going to fit a new ballast coil tonight to rectify the problem but does anyone know why it keeps blowing coils even though the sytem is ballasted
