Minivan's
Posted 30 June 2008 - 11:50 PM
Looking forward to some picks and info
Posted 01 July 2008 - 10:24 PM
With reference to the marks, I thought that the roofs were changed at some point from smooth to ribbed, or am I making this up? or did they still just call this a mark 1?
Any one got some photos of this rear seat fitted?
Posted 02 July 2008 - 07:34 AM
Posted 02 July 2008 - 12:02 PM
Posted 02 July 2008 - 12:29 PM
Posted 02 July 2008 - 07:32 PM
all vans and pick-ups were Mk1 mini variants ....
No they weren't.
Although they may have retained external hinges, sliding windows and pressed grille front panel throughout their production run they incorporated the changes to the saloon range so the Mk 2 Van and Pick-Up have a different switch panel, indicator stalk, badges etc to the Mk 1, and later they got the rod change gearbox, rubber mounted subframes etc etc.
Anyone who has a 1980 Van will tell you it is a lot different to a 1960 version.
Posted 02 July 2008 - 07:56 PM
No they weren't.
Wowow new guy, never question THE ANORAK he is the Mini geek round here.
Edited by Joshmini, 02 July 2008 - 07:57 PM.
Posted 02 July 2008 - 08:01 PM
Edited by GreaseMonkey, 02 July 2008 - 08:02 PM.
Posted 03 July 2008 - 03:12 PM
No they weren't.
OK, I'm willing to except that this is largely based on opinion
my opinion is.... the mini van and pick up dont actually have an official Mk at all, in the sense that a Mk1 mini was just a mini until the Mk2 came out.
they are however a variant of the Mk1 mini shell. yes they did receive a lot of the updates that the saloon had but they did not include the main distinguishing features that determine the changes of Mk, a different switch panel, for example, is not reason to change the Mk !!!
in contrast, the elf and hornet do have different Mks and the change points are different to the normal saloon
Edited by THE ANORAK, 03 July 2008 - 03:12 PM.
Posted 05 July 2008 - 10:09 PM
Posted 05 July 2008 - 10:17 PM
I have one of these, not fitted yet, if you want pics and measurements, its really simply to copy, let me know and i will sort them out,,
That would be cool, would also really really like some pictures of it fitted when yo fit it.
Posted 05 July 2008 - 10:19 PM
That would be great yeah please. Also very keen to see what one looks like fitted when you get round to it
Posted 07 July 2008 - 06:40 PM
That was just to give an example of the fittings that changed.
One of the main internal differences between Mk 1 and 2 shells whether saloon, Van or whatever is the larger aperture in the lower dash rail - and this is why Mk 2 onwards Vans and Pick Ups have the larger switch panel nailed on the outside of the dash rail because they didn't get the padded vinyl covered foam item.
Badging apart, it may be less obvious than with a saloon what Mk a Van or Pick-Up is because of its poverty spec but Van and Pick -Up aficionados use the same change points as the saloons when determining Mk.
Meanwhile back to the question about rear seat conversions - this is from the excellent Mk 1 Performance Conversions site http://mk1-performan...nversions.co.uk
It does require cutting of the rear load floor which is unlikely to enhance the value of a Van these days.
Edited by 62S, 07 July 2008 - 06:49 PM.
