Has Anyone has heads from swiftune??
19 replies to this topic
#1 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 07 June 2005 - 01:33 AM
I was cleaning up a head i bought which visually you can see it has been heavily modified.
from what ive measured it seems to have had a slight skim also.
while cleaning it up i found some markings and wondered if this could be a genuine SWIFTUNE head. The bloke who i got it off, never said anything about which company did the tuning parts, but he did say that it had sent it to have alot of work done on it. This was also a turbocharged engine. The head also has been skimmed on top... is this for the roller tips, this head seems wierd
The plot thickens.......
Here is a pic, showing the SWIFTUNE stamp and 20 5 (but no decimal point present)
#2 Jammy
Jammy
  • 25,397 posts
Posted 07 June 2005 - 08:20 AM
It will probably be worth giving Swiftune a ring, see what markings they usually put on their heads and where abouts they put them. But I would say if it has the Swiftune marking, chances are its Swiftune!
#3 Pavel
Pavel
  • 2,451 posts
Posted 07 June 2005 - 10:33 AM
Highly doubt someone else would bother putting swiftune on their own head lol :w00t:
Pretty sure its a swiftune head, but ring em up and ask them about the figures. (20 5)
#4 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 07 June 2005 - 03:38 PM
Well the stamps different to mine it shouldn't be offset like that and should be followed by numbers equal to it's caqpacity 1380 or 1293 etc, then a unique number which is longer than 3 three numbers. swifty can trace.
If not, then it's probably been stamped on by somebody to con someone at some point.
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 07 June 2005 - 04:49 PM
20 5 could be 20.5cc, the size of the chambers. Have you measured them ?
If they're only 20.5cc it doubtful it's been used on a large capacity Turbocharged motor, especially one running any real boost, as the compression would be far to high even with massively dished pistons.
It could also be what's skimmed off it ? 20thou on the bottom, 5thou on the top ?
Just a thought ........... :grin:
#6 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 08 June 2005 - 01:57 AM
spoke to swiftune earlier, and they said its def one of their heads, gone though what seems to have been done.
they are 20.5cc chambers with 5 thou off the top and manifold faces. we both had a good chuckle when i told him that the bloke was using it on a turbo. But as its modified already, its going to rich for the chambers to be opened up.
What kind of CC increase do you gain from removing the beak? i know its not the ideal solution to loose the beak but it'd be too good to waste a swiftune head i think :w00t:
This is one for phil - what cc do i need to start to run higher boost? like 10-12psi?
cheers for the rsp
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 08 June 2005 - 12:46 PM
What size engine is it going on ? what cc pistons ? what head gasket ? how far are the pistons from the top of the block when at TDC ?
Give me these variables and i'll give you an idea of what to aim for. :w00t:
#8 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 08 June 2005 - 03:12 PM
1275 with Morespeed turbo +040 - 10cc dish
BK450 Head Gasket
If i remember correctly the skirt was something around 20thou from the deck
once i have all the definate figures i will post up again. but was just looking for a ballpark figure so i dont overkill the head.
Dave
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 09 June 2005 - 05:47 PM
Right had a quick weigh up. :wink:
To run 12psi i'd probably aim for a compresion ratio of about 8.5-1.
1275 with +040 rebore = 1312cc
Swept volume {v} = 328cc
Pistons = 10cc
BK450 headgasket = 2.8cc
If your piston to block height is indeed 20thou as you thought, then you've got 2.04cc here.
Ring land volume = 0.80 {rough estimate}
Head chambers = 28cc
So total volume above the piston {c} = 43.64
Compression Ratio.
{v} + {c} divided by {c} = 8.51-1 compression ratio with a 28cc head, 8.69-1 with a 27cc head and 9.07 with a 25cc one.
If the pistons come higher up the block or even flush then you're going to have to take a little more from the head.
Hope this helps.
Phil. :w00t:
#10 Boab
Boab
  • 1,610 posts
  • Local Club: E*S*M*O*C
Posted 10 June 2005 - 02:15 PM
Pistons = 10cc
Compression Ratio.
Hope this helps.
Phil. :dontgetit:
:w00t: :angry: :angry: The mind boggles :cry: :P :dontgetit:
#11 wolfie
wolfie
  • 1,149 posts
Posted 10 June 2005 - 06:36 PM
boab did you buy that car from a pretty bird with a broad bristol accent lol
if so i did a fair bit of work to it
#12 Boab
Boab
  • 1,610 posts
Posted 12 June 2005 - 05:03 PM
Yes, look on page 2 of the 'to copy or not' thread and there is a pic of the beaut :(
#13 wolfie
wolfie
  • 1,149 posts
Posted 12 June 2005 - 06:12 PM
i know what laura looks like mate lol she stayed in my caravan at riviera run year before last
same year i put the steering rack on on put it though mot i think
#14 Boab
Boab
  • 1,610 posts
Posted 12 June 2005 - 06:38 PM
Lucky man :fear:
#15 Boab
Boab
  • 1,610 posts
Posted 12 June 2005 - 06:54 PM
Okay Phil, what does all the above mean, and how do you measure the 'cc' that you mention.
I can see from the pic in Bluemini's thread that a chunk has been taken away from the valve chambers, what advantages does this have.
Logic on my behalf says it makes each cylinder slightly larger, ie 73.5mm=74mm, if you get my drift or am I waffling.
What is 'swept volume'?
What do you measure to get block height?
