Removing Door Glass
9 replies to this topic
#1 c2_mad
c2_mad
  • 24 posts
Posted 02 July 2008 - 03:12 PM
hi
i have treid the search function but found nothing on this.... can any one tell me how to remove the door glass from the door??
also i cant get one of the door of cause of one dam bolt, its the very top one..any ideas? i have aready put loads of dw40 but it doesnt want to budge and teh spanner has already slipt a few times rounf the nut of a bit...
any help is much appreciated...
cheers
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 July 2008 - 03:14 PM
there's a very good bit in the Haynes manual about how to remove the door glass
#3 c2_mad
c2_mad
  • 24 posts
Posted 02 July 2008 - 03:18 PM
dont have the hynes manual....:dontgetit: any chance you coul give me the jist of it all?
Edited by c2_mad, 02 July 2008 - 03:24 PM.
#4 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 02 July 2008 - 03:34 PM
firstly remove all window trims (inner & outer) and the inner rubber-window-guide thing (soory about description); then..
to get the glass out i think you are bet of removing the winder mechanism and easing that out of the runners of the glass - would adise having a helper to hold the glass.
after you have the winder mech out, dip the front of the glass down and pull it out of the top of the door back first.
not sure which nut you are refering to either, sorry.
Wilson
#5 c2_mad
c2_mad
  • 24 posts
Posted 02 July 2008 - 04:06 PM
Wilson
hi thanks for teh help mate... will give it a go...
as fot the nut, im refering to one of the 4 nuts that hold the door on...the ones that is stuck is the one right at the top...:thumbsup:
#6 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 02 July 2008 - 04:07 PM
Wilson
your best bet is to use a socket, and if it has started to round then beat a 10mm multi socket onto it as i think they a 7/16 originally.
#7 c2_mad
c2_mad
  • 24 posts
Posted 02 July 2008 - 05:12 PM
Wilson
thanks for all the advice, will give it a go... if all else fails i might have to get the grinder out....;)
#8 Pauly
Pauly
  • 4,213 posts
Posted 02 July 2008 - 06:39 PM
Just put my door glass back in, what I do is wind the window down about 1/4, then undo the 4 screws on the winder mech. the pull the mech. back so that the little lip comes away from the door, then I actually wind the mech. down using the handle then slide it out the runners.
Haynes manual explains it better, its hard to put it in writing but the haynes is roughly the same way I do it.
Paul.
#9 captain kirk
captain kirk
  • 857 posts
Posted 02 July 2008 - 06:50 PM
as regards to your door nut,you will probably find once you put a socket on it and if its that stuck it will more than likely snap off mine did :thumbsup:
#10 c2_mad
c2_mad
  • 24 posts
Posted 02 July 2008 - 07:09 PM
the door glass is out... it pretty simple actually... its jsut like you guys explained....
here is a link to the instructions if any body needs them....
http://drcwww.uvt.nl...l/bodyacc/5.htm
as for teh nut i didnt touch it today... will have a look at it tomorrow, but if it gives me to much of a hard time,i ll get midevil on it with the grinder... ;)
thanks for all the help guys....
