1991
fitting an mpi oil temp gauge
Hi, quick question, i have just bought a 3 + 3 Rover dash and was wondering how to go about fitting the oil temp gauge.
I have the wiring loom for the 3 gauges and have figured out how to do the clock, volts and the dial illumination. Now, the bit i'm stuck with is how to wire in the oil temp gauge, i'm guessing the white is a switched live as this is tapped into the white wire that feeds voltmeter (tested off a small 12v battery)
I take it the other wire on the gauge goes to the oil temp sender?
Also, where do i fit the temp. sender and how?
Here's some pics of the gauges and a quick wiring list of what i think does what..
Please correct me if i'm wrong with this.
Back of oil gauge
Where the 2 whites are joined inside factory loom
Same white as above going to volt gauge
And my quick wiring notes which i think should be correct
So providing i have the above correct, how would i go about fitting the oil temp sender?
Thanks in advance
Mark.
