Auto Gearboxes
Posted 11 July 2008 - 12:17 PM
For medical reasons my missus can only drive auto, so my next mini will prob be auto so she can join the fun......I wandered what the boxes are like as in most small autos economy and performance are both compromised by the gear ratios, is this the case with mini's?
And am I correct in thinking they are all 4 speed whether fitted to a 1275 or 998?
Your comments and experience are very much appreciated as I want to get the missus interested so she doesn't moan about me spending lots of money! lol.
Posted 11 July 2008 - 12:54 PM
TMF member 'GuessWorks' is probably the best bloke to speak to. He's definately in the know on all things 'manual', and I expect he knws a fair bit about auto's too.
If he doesn't post on here in the next few days, drom him a PM and ask.
Cheers!
P.S. Know exactly where you're coming from with the 'get-the-missus-a-mini-to-stop-her-moaning-about-my-spending-all-my-money-on-my-other-lady-and-not-on-her' angle! Picking hers up in a couple of weeks
Posted 11 July 2008 - 05:26 PM
It wasn't as revvy as my manual 998 but it just about held its own on the motorway etc. Fuel consumption was about the same as the manual 998.
I would say go for a 1275 if you can find one as I did find the 998 a bit restrictive sometimes. Yes, all 4 speed. They do need more maintenance than a manual box though. You need to treat them with care and change the oil more often.
Posted 11 July 2008 - 05:32 PM
IT MUST HAVE A FULL SERVICE HISTORY AND LOW MILEAGE
otherwise you're asking for trouble.
Posted 11 July 2008 - 06:03 PM
Her car is low milage so no problems yet, and it's still fun to drive!
Posted 11 July 2008 - 06:05 PM
Guessworks, I would have gone low mileage if buying an auto but rarely see FSH minis for a reasonable price! Are there any specific signs I should look for when test driving? I take it they are a bit more fragile, and able to handle less tuning?
Cheers guys
Posted 11 July 2008 - 09:49 PM
1..purchase 2 bottles of engine flushing oil..............
2..remove drain plug and take out 1lts oil and put drain plug back..............
3..then pour in 1 bottle of flushing oil and place trolly jack under gearbox and lift untill wheels are just off ground............
4..start engine and run for to mins moving through auto gears back and forth severl times this activates tiny plungers in box and cleanse them.....
5..after 20 mins switch off and drain oil (carefull very hot) and remove filter. check old oil for brass flakes, if there are any then your box may need a rebuilb .......
6..if not replace drain plug and fit new oil canister and put 2nd bottle of flushing oil in and top up with cheap oil and go for a 20 mile drive and then drain and put in a good guality oil there no need to put new canister in .............
good luck..................
Posted 12 July 2008 - 06:41 AM
With auto's because of their reputation, sometimes misplaced, they are generally cheaper....In preference I'd go for a 1275 auto... They use the last generation of the auto box which is the strongest of the lot. They are not so much fragile, but if not maintained machincally will go down hill VERY fast.
Talking of going fast, they do that too, many have a long final drive which makes for really good cruising speeds, and don't suffer from the poor acceleration which long finaldrive manuals do.
Posted 12 July 2008 - 07:11 AM
Posted 12 July 2008 - 01:54 PM
The long final drive is also appealing as i do have to cruise up the dual carriageway for work, and a few motorway miles each weekend to see family, so very much a bonus there!
I would have hoped for a bit more than 37 to the gallon, but its still better than the last couple of motors i've had! Lol
