Double Tanks
25 replies to this topic
#1 kez_19
kez_19
  • 946 posts
Posted 14 July 2008 - 10:41 AM
i have seen that some minis i believe that they are all coopers have 2 filler caps one on each side...... is it because they have 2 tanks or is it just for looks???? if they have 2 tanks do they take fuel from both tanks at the same time and into some sort of a t junction then to the engine or do they empty one tank then switch over to the next tank?????????????????????????
thanks for any help and advice
michael :proud:
#2 jpd
jpd
  • 56 posts
  • Local Club: minis'n'oatcakes
Posted 14 July 2008 - 11:26 AM
i have twin tank setup on my '92 italian job.
one tank is std size, the other is smaller c. 20 or 40L
both tabks feed into a T junction, with fuel filter on each end, having them going into a T junction pipe rules out the need for two fuel guages. I suppose a cut off switch could be fitted to the smaller tank, for around the town/short distance driving, but not really that necessary
#3 kez_19
kez_19
  • 946 posts
Posted 14 July 2008 - 12:27 PM
thats great news and easy to do as well
do you have a smaller one for any special reason (lack of space etc )??
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 July 2008 - 02:14 PM
The right hand fuel tank was originally an option on Cooper S models and eventually became standard on them. It has been a very popular modification for all Minis ever since. It is smaller for one reason mainly, when it was first available the standard tank was smaller too at 5 1/2 gallons compared to the 7 1/2 that later Minis have. The right hand tank tooling was made by adapting the press parts from the original tank so it is the same size as the 5 1/2 gallon left hander. When the new larger tank was first fitted no Minis were fitted with right hand tanks as standard so a larger tank wasn't designed for the other side. Also a larger tank would make battery access tricky, even the small right hand tank overhangs the battery. Nobody needs 15 gallons of fuel capacity in a Mini anyway, and the boot would end up being tiny. If I was fitting a right hander I would swap my large left hand tank for the smaller one. 11 gallons is quite enough (and weighs enough).
;) Smaller at 40 litres! How big is your left hand tank? It's only meant to be 34 litres!
#5 kez_19
kez_19
  • 946 posts
Posted 14 July 2008 - 02:33 PM
well actually the reason i am asking is because i live in northern Sweden and it can be a bit far between petrol stations so when i saw a couple of minis with double tanks i wasn't sure if it was possible or just decoration ;)
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 14 July 2008 - 05:57 PM
The original Cooper S was ground breaking in most forms of Motorsport, so no it wasn't just decorational: -
#7 MarkGTT
MarkGTT
  • 528 posts
Posted 14 July 2008 - 06:28 PM
It was also used for better weight distribution not just extra fuel capacity.
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 14 July 2008 - 06:49 PM
You can fit R/H tank to your mini its not to hard as I'v just done mine............... ;)
#9 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 14 July 2008 - 07:32 PM
I have a modified Left handed tank on the right and a larger original on the left. Holds lots and lots of super unleaded ;)
..... and a big tank of nitrous inbetween.
#10 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 14 July 2008 - 08:02 PM
Did you just use a BFH? or did you chop some out and re-weld? also did you have to re-weld the fuel neck?
#11 kez_19
kez_19
  • 946 posts
Posted 14 July 2008 - 08:43 PM
did you have to modify your tank/s to get them to fit if so what did you have to do??
did you find the same problem as mentioned earlier in the thread about access to the battery
#12 mk1leg
mk1leg
  • 9,343 posts
Posted 14 July 2008 - 09:38 PM
No, access to battery is as the same as I fitted an orignal R/H tank................... :thumbsup:
#13 biggav
biggav
  • 5,830 posts
Posted 15 July 2008 - 09:59 AM
My modifies lh tank just had the filler neck cut off and re-attached in a different position and a plate welded in the hole that was left... i bought it already done.
#14 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 15 July 2008 - 10:23 AM
Cheers :thumbsup: Looks like ill be buying another tank to have a play with lol, also when filling that tanks up, do you just fill from 1 side and it just self levels? or do you have to fill both sides?
#15 Ethel
  • 26,141 posts
Posted 15 July 2008 - 10:34 AM
They will self level, but a lot slower than you can fill them.
