Rear Subframe Bolts Loose
2 replies to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 14 July 2008 - 08:56 PM
Being driving my new build for 2 days and decided to check my rear subframe bolts. They were quite loose. I tightened all 8 up to 30 newton meters. Is that enough. Really worried about these. Rang heritage for a torque setting but they have none and I dont like the FT rule. Advice please should I tighten them further.
Zeroasylum
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 14 July 2008 - 09:17 PM
If you know what grade steel the bolts are then this guide might give you a clue, its in ft lb's
http://www.sizes.com...lts_SAEtork.htm
#3 zeroasylum
zeroasylum
  • 378 posts
Posted 14 July 2008 - 09:41 PM
The bolts have 3 lines on the head and an L is that SAE grade 5. They are the mini spares 5/16" ones. According to this they should be done up to 25nm
http://drcwww.uvt.nl...nual/torque.htm
And from your table 15 foot pounds when multiplied by 1.3558 to convert gives approx 20nm so I think mine are ok. But it seems very low fo such an important item. Am I right what do you think. Any other opinions
Zeroasylum
