Car starts and runs easily first time every time, but within 30 seconds you hear the familiar whine of the fuel pump slow and then stop and the car stalls.
Originally it started doing once every 20 minutes or so whilst driving. Gradually it got worse and worse until now it generally won't drive, although If I start the car over and over (ie after 3 or 4 stalls) eventually I get it running for longer periods- say 3 or 4 minutes and I sometimes get it off the drive for a quick burst. Last night I had it running well but ultimately it still cut out.
I have tried everything I can think of:
All plugs pulled apart, cleaned, WD40'd, put back together
Wires checked for splits
Any dodgy connections replaced
Inertia Switch unplugged and bridged with wire (proving its not that)
ECU removed, connections cleaned, airing cupboard over night.
MAP sensor pipes removed, cleaned, unclogged and put back
Disconnected everything other than the main circuits to eliminate any shorts (lights, stereo etc)
Tank removed, respositioned, connections cleaned.
Fresh fuel added
Injection cleaner added
All fuses removed, cleaned WD40'd and replaced
Garage heated
Heater left on inside car
Relay module tested and working. With the cover off you can see the relays working, and when the pump dies these remain on and connected.
I am confused because sometimes its better than other days.
The car has only done 50000 miles and under the bonnet is clean and all the electrics look like new still.
Any more suggestions?
By the way its a 96 so doesnt have in line fuses. No fuses are popping as a result of this problem.
Edited by cooperspi, 15 July 2008 - 12:44 PM.
