Water Pump Not Pumping At Idle?
4 replies to this topic
#1 BigDave99
BigDave99
  • 186 posts
  • Local Club: NA
Posted 16 July 2008 - 07:11 PM
Hello
Just fitted a new engine to my 1995 1275 SPI mayfair, i put in a 1275 metro carb engine! Got everything going and works lovely, one big problem - at idle she overheats very quickly! when investigating the pproblem with hose pipe and a hose i found that the water pump does not pump the water around at idle. as soon as the engine is revd and then held at a higher rpm the water flows fine. if you then drop it back down to idle the flow stops! Obviously a big problem when sitting in traffic! Why could this be? Could the rad be blocked and then only at a higher rpm does it suck the water out and round?
All suggestions welcome and appreciated!
Dave
#2 minicooper1.3i
minicooper1.3i
  • 873 posts
  • Local Club: na
Posted 17 July 2008 - 06:49 AM
Have you checked the fan belt? For wear and correct tension? And how old is the actual pump? If the belt is OK see about getting a new pump and flushing coolant out / through. New pumps aren't all that pricey or difficult to fit.
#3 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 17 July 2008 - 07:37 AM
I'd definitely get a new pump on it, and a new thermostat.
Cheap plastic impeller pumps regularly loose their fixing onto the impeller, and on a very old metal one the blades can rot away.
Also, a smaller water pump pulley could help if you are currently running a large one.
#4 BigDave99
BigDave99
  • 186 posts
  • Local Club: NA
Posted 17 July 2008 - 05:53 PM
Water pump and belt are new, tension is fine! Im stumped, i flushed the whole system too!
#5 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 17 July 2008 - 06:08 PM
Is it the correct pump?? As mentioned there are pumps with smaller impeller!!
Edited by mini_kel, 17 July 2008 - 06:08 PM.
