Sunroof Leaking
10 replies to this topic
#1 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 18 July 2008 - 06:38 PM
hey people, a little problem. When i got the mini the sun roof was leaking so obviously it needs a new seal right ? ive been trying to look for one and cant find one :thumbsup: can someone help me please or give me a idea how to fix it thanks
#2 luke6040
luke6040
  • 449 posts
  • Local Club: na
Posted 18 July 2008 - 07:01 PM
As a short term fix while you are looking, put a think smear of Vaseline around the edge should seal it until you find a new rubber.
Edited by luke6040, 18 July 2008 - 07:01 PM.
#3 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 18 July 2008 - 07:04 PM
Ok ill give it ago :dontgetit: :thumbsup: thanks any more ideas poepl ?
#4 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 21 July 2008 - 03:32 PM
bump
#5 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 21 July 2008 - 03:38 PM
Any family planning clinic will tell you not to use oil based lube on rubber - but as the seal is knacked already I don't suppose that matters - plus ky jelly on your roof may be a little embarassing.
You ain't likely to get a new seal unless someone like Woolies does them - which I doubt. Best bet either full new sunroof, or brand new second hand seal from the scrappers.
#6 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 21 July 2008 - 03:41 PM
oh ok then cheers mate
#7 luke6040
luke6040
  • 449 posts
  • Local Club: na
Posted 21 July 2008 - 04:01 PM
The ky was just a temp fix idea, i wouldnt go to a show with it on lol.
Iv used on another car in the past, didnt seem to do any harm in the short time it was on.
This guy might help
http://www.iwestmidl...;s-Mini-Centre/
Nice bloke very helpful.
Have you had a look on somewhere like ebay.
#8 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 21 July 2008 - 04:03 PM
thanks and yep have searched everywhere cant find anything :shy:
#9 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 21 July 2008 - 04:16 PM
Is your sunroof just a glass flick up one? If so, it's very unlikely a new seal will be available from anywhere. Cheap replacement ones can be had from the shows for about 20 quid. You might find that you could pop the seal out of one of these and replace yours without changing the entire unit - as they'll likely be the same.
I'd still get down to the scrappers first.
#10 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 21 July 2008 - 08:38 PM
Or try a Land Rover dealers, because I'm told that either the early 1990's Defender or Discovery used the same type of sunroof seal as many a Mini including the 1990 RSP LE.
I.E. a Tudor Webasto Sunrise type of glass sunroof.
#11 jordie 08
jordie 08
  • 489 posts
  • Local Club: no club
Posted 21 July 2008 - 09:52 PM
i couldnt get a seal and mines has silicone right around the thing and its stoped leaking i think,not had alot of rain since
