right how do i wire an mg metro dizzy to a standard loom all i have is the dizzy and the module the module has three pins in it any ideas i have found a wiring diagram but for the wrong dizzy and wich pin is wich
Metro Electronic Distributor Wiring
hcmini1989
, Jul 23 2008 09:21 PM
2 replies to this topic
Posted 23 July 2008 - 09:21 PM
Posted 24 July 2008 - 05:44 PM
comon please some bodyright how do i wire an mg metro dizzy to a standard loom all i have is the dizzy and the module the module has three pins in it any ideas i have found a wiring diagram but for the wrong dizzy and wich pin is wich
Posted 25 July 2008 - 07:53 AM
One of the connectors doesn't connect to anything, then I think one has to have a live feed, and one goes to neg side of coil. I don't think I've got a picture of mine wired up, but I just tried each combination until something made a spark, and went with that... Not very professional I know, but it worked, and there's only 6 combinations!
Found a pic. Turned out I got a connector plug of a Metro, and then just joined the two wires to it, so it was a 1 in 2 chance, here's the pic, but I'm not sure if you can make it out...
Dave
Dave
