Engine Wont Turn Over But Did Yesterday ?
Posted 24 July 2008 - 09:16 PM
Posted 24 July 2008 - 09:25 PM
my mini did turn over but now wont
but its making a clicking noise at the box in the top right corner. so this means that the power it not going threw the box to the starter moter, that is at the top right corner that is conected to the inner drivers wing what it that box called and what is the corse of the clicking noise as i go for turn it over :@:@ stressed lol my mini is being fussy with me :@ sorted my probles and 1 more pops up thanks for the info ben
sorry faulse info top lest as u look from the front lol sorry people
Posted 24 July 2008 - 09:58 PM
sorry faulse info top lest as u look from the front lol sorry peopledosey me lol
The "Box" what i believe your describing is the starter relay, it could well be a faulty relay which is causing your problem but it could also be the relay isnt getting a live feed ( on a relay ther are two live feeds, one is a switched live to control the switchover, the second is the main feed to deliver the power to the comonent which needs the extra current) , if its the metal bodied type ive took the metal cover off and cleaned up the contacts to some sucess, but as there not expensive its just as easy to buy a new one.
Edited by john1.2pearl, 24 July 2008 - 10:03 PM.
Posted 24 July 2008 - 10:03 PM
The "Box" what i believe your describing is the starter relay could well be a faulty relay, if its the metal bodied type ive took the metal cover off and cleaned up the contacts to some sucess, but as there not expensive its just as easy to buy a new one.
lol another one to add to my list lol ive got to get tomorrow is
wiper relay
indecator relay
2 repeater bulblsand all new other builbs
will i be able to get all these at whiston motofactors or will i have to go to a mini speshalist. spelling sorry thanks for that
Posted 24 July 2008 - 10:05 PM
Posted 24 July 2008 - 10:06 PM
Posted 24 July 2008 - 10:07 PM
Have you tried jump starting it, sounds like a flat/faulty battery, they often give no warning of problems at all, just won't start one morning.
Try the above first as this may be the cause !! I assumed you had a charged battery
Edited by john1.2pearl, 24 July 2008 - 10:08 PM.
Posted 24 July 2008 - 10:30 PM
Try the above first as this may be the cause !! I assumed you had a charged batteryoops !
yep all last night as i flattend it yesterday
Posted 24 July 2008 - 10:38 PM
Posted 24 July 2008 - 10:45 PM
If you flattened it yesterday and it won't start today, i'd still say the battery has had it, when they are over discharged it takes a really good set of jump leads to start again as the completely flat battery will take all the power trying to charge. That's if it will go at all, some cheap jump leads won't let enough power through to start a moped let alone a car engine. If you have a charger put it on charge and leave it overnight then take it to somebody to check out (most fast fit centres will check it for nothing)
it was only bough about 5 mounth ago lol ive recharged it 3 times in total it started turning over slowely and tuk it of and recharged it over night and its still full (water) so this sould still turn over the engin and it wasent making that naose last time it went flat so it must be the relay :@ lol ah well good news then ehh thanks
Posted 24 July 2008 - 11:42 PM
so ive just got to change my starter relay i hope as its a newish battery ive ha two recharge it 3 times and that was a full 12 hours (over night) so it must just be the starter relay as its just clicking from it and newt is happening and has never done the before untill now so that must be the problemIf you flattened it yesterday and it won't start today, i'd still say the battery has had it, when they are over discharged it takes a really good set of jump leads to start again as the completely flat battery will take all the power trying to charge. That's if it will go at all, some cheap jump leads won't let enough power through to start a moped let alone a car engine. If you have a charger put it on charge and leave it overnight then take it to somebody to check out (most fast fit centres will check it for nothing)
it was only bough about 5 mounth ago lol ive recharged it 3 times in total it started turning over slowely and tuk it of and recharged it over night and its still full (water) so this sould still turn over the engin and it wasent making that naose last time it went flat so it must be the relay :@ lol ah well good news then ehh thanks... i havent tryed bumping it its bin stood for about neli a year now as i bought it as to tide up for put on the road and slighty mod it body wide like debumpering it and sport pack alloys and arches and then a respray after its moted i havent even got nuber plates with it so i wouldent like try to bump it as i havent even passed me driving test yet and having no inshurenc (spelling)
lol thanks
Posted 25 July 2008 - 07:42 AM
relay and battery check,if not whip the starter motor out and clean it up check its kosha.worked for me
Posted 25 July 2008 - 02:15 PM
thanks mitchalso check your starter motor isnt jammed in the flywheel.if this is the case jump starting it will ruin your life!! im talking from experience!!
