Designer:
88:
Iv got a problem with my dipped beam and main beam as they don't work (bulbs and wiring seem fine), iv narrowed it down (the best i can) to the pink replay near the steering column
the austin/rover number (i think) is DRC6520 and the lucas number is 37805A
can anyone help?
EDIT: And where can I get 1 from?
I think I have the same problem - trying to diagnose if DimDip relay is the culpret
1989 Mini 998 twin cluster. Relay is marked Lucas 13DA; 12 volt naturally; DRC6520.
I had to rebuild the side / headlight swith, and improve the contacts onto the back of the switch, using appropriate slim screwdrivers to crimp the contacts a bit better, as they had been arcing.
The full beam flash works fine,
The sidelights turned on then the Dim Dip works fine with ignition on.
When I turn on headlights though they don't work neither full nor the normal power dip.
I have been checking the fuses in main 4 fuse box, as well as the triple line fuse blovk at back of air filter.
the rear fog also not working because I assume headlights not working.
Have I said enough to narrow it down to the DimDip Relay DRC6520. If it were poor earth at the headlights then the flash and dim would also not work.
Ay ideas welcome.
Edited by ostridge, 24 July 2009 - 09:39 PM.
