Noisy Minisport 1.3 Roller Tip Rockers
Posted 25 July 2008 - 11:12 PM
Just wanted to know if anyone else has had a problem with Minisport roller tip rockers being noisy. I have had them for about a year but only just fitted them (c. 200 miles ago), so cannot really return them. They were always a bit loose feeling on the rocker bar!
I am running 1.3:1 on a 998 with an SW5 cam at 15 thou.
I don't really want to replace them as they aren't cheap. Can anyone suggest standard replacement ones which are 1.3:1?
I also checked out to see if they were hitting the rocker cover, but it doesn't seem that they are.
Help, I spent a fortune getting the engine sorted out and it sounds worse than my 105k miles 850!
Posted 25 July 2008 - 11:18 PM
Hello all,
definately all feeler-guaged up correctly? mine were pretty good, nice and quiet compared to what i had prior
Posted 26 July 2008 - 06:51 AM
Moved to Technical and Problems.
Posted 26 July 2008 - 08:27 AM
Posted 26 July 2008 - 09:23 AM
I have always wondered what 'a good sliding fit meant', in terms of gapping the rockers in the first place. I go until the feeler gauge is just starting to be caught. Is this correct?
Thanks for that.
Posted 26 July 2008 - 08:45 PM
Yeah, I was measuring from front to back, I will try side to side.
Thanks for that.
Sounds right to me.
Posted 26 July 2008 - 09:45 PM
Posted 26 July 2008 - 09:48 PM
I would contact minisport and ask what they would do, as I have just removed a pair of minisport rockers with a snapped shaft. on inspection the shaft was only half as thick as a pair I bought from mini spares. couldn't take the back dew to the length of time I have them before fitting them. it snapped while I was drive and I noticed it sounded very tappy, got home took rocker cover off and no.8 tappet almost fell off in my hand. lucky or what
that happened to alex also.
Posted 26 July 2008 - 10:29 PM
I would rather remove them and fit some I will have better faith in. I might swap then for std ones whilst on the r/road next week and see if the is any difference at all between the std 1.22:1 and the 1.3:1! I will post the outcome.
I should have though that the swiftune of KAD ones should be better, but I don't think they do 1.3:1 for small bore heads. I only want them for the extra left anyway so maybe try and source some 1.3:1 oem std rockers, anyone know what they were fitted to Cooper s etc??
Posted 26 July 2008 - 10:58 PM
You hear a lot of horror stories about the minisport rockers, the two most common things i've heard of is the pins that hold the rollers in have fallen out, and the shafts breaking. I dont think i could be persuaded to use a set after some of the stories i've heard. On the other hand the Titans are horrendously expensive, £340 or something, and are completely unnecessary for a little budget motor. I'd keep an eye out for some of pressed steel ones as mentioned before.
Posted 26 July 2008 - 11:21 PM
I did a lot of work in one hit on my engine so too many variables to compare the rockers.
Anyone here got any comments e.g. are they necessary on a engine of my spec?
Thanks all for help.
Posted 27 July 2008 - 12:08 AM
http://www.minispare...le.aspx?aid=142
According to this the Minisport 1.3:1 are actually 1.27:1. Given this with my swiftune sw5 cam:-
Lobe lift of 0.281inch
Std 1.22:1 valve lift 0.343inch
1.3:1 valve lift 0.365inch
1.27:1 valve lift 0.357
Which is 14thou (0.36mm) more than std, doesn't sound like much. Atleast this means that I can replace the noisy roller rockers with Cooper S forged rockers and get the same ratio.
I would like to see some figures to see if this makes any difference!
Matt
