Inline Fuse Melted!
Posted 28 July 2008 - 01:12 PM
1975:
noticed last night my interior lights arent working, no prob i thought, just swap the fuse, but when i got to the fuse, its melted and in 2 halves (the plastic inline fuse holder i mean)
any ideas why this might be happening?! only thing i've changed is that i hardwired my road angel in last night, to the same circuit, would that cause it to melt though? the actual fuse is still intact, so it didnt blow the fuse, just melted the holder! very odd!
Posted 28 July 2008 - 01:30 PM
One of my in-line fuse holders was melted on my Mini when I first bought it. It was the one that runs the dim-dip lighting and the problem was with the in-line fuse holder itself which had a chunk of left over plastic stopping the fuse from making good contact.
I just replaced the in-line fuse and it's been fine ever since.
Posted 28 July 2008 - 01:49 PM
Posted 28 July 2008 - 02:42 PM
Posted 28 July 2008 - 04:10 PM
For those who still have their original fuse holder, consider taking them apart and using Scotchbrite to clean the fuse ends and the fuse holder contacts. Apply a bit of dielectric grease or Vaseline to the contact surfaces (and the spring) before re-assembly. The metal to metal contact will push the grease out of the way but what remains will keep moisture away from the surfaces which assures good metal to metal contact.
Posted 28 July 2008 - 04:17 PM
Posted 28 July 2008 - 05:07 PM
Just to add, if your thinking about changing to blade fuses, they aren't rated the same as glass fuses. And there really shouldn't be much heat from the carb (exhaust) anyway, unless you spent most of your time sat in traffic jams and hot weather.our hazzard lights stopped working and it was due to the in line fuse's behind the air filter had melted, they are very simple things and melt easily, i would sugest changing them with the u shaped fuses and holders, the heat from the carb will make them melt over time.
Posted 28 July 2008 - 05:25 PM
Posted 04 September 2008 - 07:55 PM
