Not bad for 65 quid total! Headunit is a Kenwood KDC W4031 (25 off ebay) and the speakers are Alpine SPE17 C2's (30 local car audio shop, also the same price on www.lowcostcaraudio.co.uk), 10 for the DIN tray.
Speakers are 17cm, and as you can see, a little bit of hole-enlargement was required get them to fit - but it's really easy. Just put 10 or so cuts around the circumference of the hole, then using a pair of pliers, "peel" each tab back a nadgers.
It's obviously not in the same league as the 5 series audio system, but for 17cm speakers they pack a reasonable punch just running off the headunit - certainly enough to be able to feel the music as well as hear it, so I'm prety pleased - as I didn't want to go spending loads of money and putting amps/subs in.
Edited by Russ528, 30 July 2008 - 07:01 AM.
